peter lena 8,970 #1 Posted July 3, 2024 just did a filter swap , pan tablets , lubricating fluid on coil ends , for water shedding , been doing this over 30 years , made numerous small functional changes for more thorough service . easier access , and staying after , moisture movement , shed has eliminated any build up . best investment on the house . pete 1 Share this post Link to post Share on other sites
ri702bill 8,729 #2 Posted July 3, 2024 Excellent advise. That is one reason I do my own oil changes - gives me a chance to get up close & personal with the vehicle I trust to get me from point A to piont B and back. Gives me a chance to look for fluid leaks & check fluid levels.... 1 Share this post Link to post Share on other sites
peter lena 8,970 #3 Posted July 3, 2024 @ri702bill bill , use aerosol FLUID FILM on the coil ends , that was just a trial , but was thinking it would enhance the water dropping , amazing slick finish also did the inside of the lower coil drip tray . there is zero rust on any joint or moisture point ! was volunteered to assist an outside A/C guy at pfizer , learned so much in a month , gave me an entirely different view of A/C maintenance . get that fluid film into a dry seam inside / out if you can , 30 years old and no rot / rust , that sits next to my sump pump pit , also loaded with tricked out altered pump piping , for a valve switch to change discharge from street drain to lawn . also add those pan tablets to the water discharge , electric motor sump / for clean / clear discharge . thanks for the shout , pete Share this post Link to post Share on other sites
