JoeM 7,874 #1 Posted July 2 For a while now I used a website https://outdoorpowerinfo.com/belts/toro_belts.asp for finding the length and width of WH belts by Toro part number. The site is now gone. Is there a chart that shows this info somewhere here? I have found charts that give the WH number but not the size. Share this post Link to post Share on other sites
ri702bill 8,327 #2 Posted July 2 Garry has done a nice job of giving Belt size dimensions in the sidebar where you download the Manual for your tractor. Usually gives the WH part number, inside dimension (which can sometimes be a screwy size, like 55-7/8"). He tells you if it is or isn't OK to use a standard 56" belt........ Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #3 Posted July 2 There are mistakes in the Wheel Horse charts. At the end of that file the dimensions are listed. Have tried to include the belts in the file description page for each model's parts list - saves having to download anything for the belt info. 1 Share this post Link to post Share on other sites
daveoman1966 3,752 #4 Posted July 3 Belt sizes are shown on this website... Just enter the OEM belt number and PRESTO--- size is given. I've been using this place for years. https://outdoorpowerinfo.com/belts/ Share this post Link to post Share on other sites
JoeM 7,874 #5 Posted July 3 3 hours ago, daveoman1966 said: I've been using this place for years Me too. Lately, this error comes up. Try it on your end and let me know. Might be something wrong with my system?? Share this post Link to post Share on other sites
Retired Wrencher 5,464 #6 Posted July 3 11 hours ago, ri702bill said: Garry has done a nice job of giving Belt size dimensions in the sidebar where you download the Manual for your tractor. Usually gives the WH part number, inside dimension (which can sometimes be a screwy size, like 55-7/8"). He tells you if it is or isn't OK to use a standard 56" belt........ I have been using this for awhile. Look up model and the info is there for what belt you need. Very handy to have. Thanks Garry for all your hard work on this. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,046 #7 Posted July 3 If you know the belt number and want dimensions click on the empty search box. That will bring up a drop-down menu. Select FILES. Now type in the belt number and search. The results will include the belt dimensions from the Wheel Horse chart for every tractor or attachment that uses that belt. Share this post Link to post Share on other sites
JoeM 7,874 #8 Posted July 3 I did find this list on RS. I do a lot of custom stuff not machine specific. Sometimes i know the size and want to see if there is a WH part for the size. I was just thinking there was a list in spread sheet form. This is a sample of the post. Share this post Link to post Share on other sites
