JimSraj 429 #1 Posted July 2 Anyone confirm that a 79360 snowblower will work with a 1991 312-8 and/or a 1993 310-8? I see that it works with 300, 400 and 500 series so seems like it should but the 79360 looks like it was made in 1994 so im not sure. Share this post Link to post Share on other sites
JCM 9,163 #2 Posted July 2 Yes it should fit both. Will be lacking HP though. 2 Share this post Link to post Share on other sites
953 nut 55,223 #3 Posted July 2 This chart will give you conformation on what attachments will fit each tractor. Share this post Link to post Share on other sites
peter lena 8,625 #4 Posted July 2 @JimSraj another thing about blowers , is the ROTATIONAL MOVEMENT RUNNING EASE , that is typically ignored , those related pulleys / related frame movement areas , are typically solid rust . and lubrication failed . a standard that I have on PTO BELT DRIVEN anything , is initial belt drive to it , does it move easily ? how sloppy are connection points ? added washers , green grease , idler pulleys tiny bearings / lubrication failure . ever listen to mule drive , scream / howl at attempted engagement ? It starts next to the battery , mount point , the sloppy PTO lever set up . lots to make better , pete 1 Share this post Link to post Share on other sites
JimSraj 429 #5 Posted July 2 Thank you all. I’ve downloaded and printed the pages that apply to my 3 tractors. 1 Share this post Link to post Share on other sites
