Vintner 17 #1 Posted June 29 I can't find a source for a new clutch plate for my 1984 WH tractor. Can anyone point me in the right direction? TIA Share this post Link to post Share on other sites
8ntruck 7,079 #2 Posted June 29 Try your local Toro dealer. You will need to have your model number and serial number for them to be able to look up the clutch plate. Kind of pricey, though - $120ish. Some of the dealers here in the forum should be able to help with a relining kit, a used clutch plate, or possibly a new plate at lower price than the Toro dealer. Share this post Link to post Share on other sites
Racinbob 11,194 #3 Posted June 29 Assuming you mean the PTO clutch there's two diameters that I know of. I just don't know what tractors take what. Share this post Link to post Share on other sites
lynnmor 7,352 #4 Posted June 29 Just google it and you will find tons of them, new, used and aftermarket. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #5 Posted June 29 Guessing you have a 1985 310-8 model 21-10K801. Here is a parts list so you can come up with the original part number so you can find a replacement. Share this post Link to post Share on other sites
oliver2-44 9,847 #6 Posted June 29 Contact K and B Horse P, he's on eof our vendors. I seem to recall his clutch material may be slightly thicker that the Toro material. https://www.wheelhorseforum.com/forum/177-kb-horse-parts/ 1 2 Share this post Link to post Share on other sites
76c12091520h 3,668 #7 Posted June 30 9 hours ago, Vintner said: I can't find a source for a new clutch plate for my 1984 WH tractor. Can anyone point me in the right direction? TIA Share this post Link to post Share on other sites
Mark siebenaler 93 #8 Posted June 30 10 hours ago, Vintner said: I can't find a source for a new clutch plate for my 1984 WH tractor. Can anyone point me in the right direction? TIA You can call Lowell he has em. Share this post Link to post Share on other sites
peter lena 8,716 #9 Posted June 30 @Vintner , ever check out the PTO DRIVE BELT EFFORT TO MOVE DECK BY HAND ? mine easily rotate that down belt section . have also long removed the drag break long ago , since going to 550 deg related grease , that entire lever drive set up , really responds to a functional detailing / lubrication change out / upgrade . no screaming , squealing clutch , just solid smooth lever engagement . it starts at the , side of battery frame area , the continued drag / on every phase , collectively , eats clutches . another thing I change out was the sloppy trunnion end joint , a HEIM joint very smoothly replaced that . not in the book , pete Share this post Link to post Share on other sites
Vintner 17 #10 Posted June 30 16 hours ago, 76c12091520h said: How do I order 1 of these? Share this post Link to post Share on other sites
76c12091520h 3,668 #11 Posted July 1 5 hours ago, Vintner said: Gimme a call or text during normal business hours, or private message me right here on Red Square Share this post Link to post Share on other sites
