Richard Wahlstrand 81 #1 Posted June 29, 2024 I thought that I had a stuck/frozen choke cable on my 314-H. After removing the cable from the engine, I slipped a 6-inch length of 1/4-inch fuel line over the cable and attached it with a screw-type hose clamp. With the end vertical, I filled the fuel line with marvel oil (less than a teaspoon) and let it drain into the cable. It only took a few seconds. There was little mess. The lubrication should last several years. My problem was a stuck choke shaft in the carburetor. Loosened it with a few drops of marvel. 3 Share this post Link to post Share on other sites
peter lena 10,013 #2 Posted June 29, 2024 @Richard Wahlstrand https://www.zoro.com/super-lube-4-oz-bottle-hydraulic-oil-68-iso-viscosity-80w-sae-52004/i/G2272326/?g been using this for years , local H/W store , check out temp range , another thing I have regularly used , is to add very light spring pull assist to , the multi holed mount point of cable end , always add to assist pull to stop on cable . that way you always have an assist to cable function , have that set up on my 3 horses, smooth easy , pete Share this post Link to post Share on other sites
ri702bill 12,802 #3 Posted June 29, 2024 Cable treatment with MMO is a regular service item for me - they get removed, positioned vertically and MMO added. I do this at least every year & a half - both tractors see 4 season use.... 3 Share this post Link to post Share on other sites
peter lena 10,013 #4 Posted June 29, 2024 @ri702bill agree with you on the regular cable function maintenance ! most if not all of the related cables I see are frozen solid , or barely function , WHAT COULD YOU POSIBLE DO TO MAKE IT MOVE ? another part of that is RELATED LINKAGE POINTS , guy up the road from me , has 2 horses and 3 work horses , just rotting / rusting away in a shed , but he wants top money ( laughable ) because its a wheel horse . sure you have seen similar , BTW small extension springs to cable movement end connections , make for effortless movement , ( don't tell any one ) , stay greasy pete 1 Share this post Link to post Share on other sites
