quahog
 OK  I  am  struggling  here : Mower deck  42  Inch as  fitted  to  my NEW TO  ME  314 -8. ,   Model 73448 .  I  am  not   100 %  on  the   year  of the  tractor  even  !    87 ?  85 ?  , manual printed  in 1997.  I  would  like  to  pinpoint  the   42 in  deck  to  view   the  owners  manual  this   group offers. No  model  sticker on  it.  Its   a  new   treat  as  it   works   great  and  I  love  my  deckless  845  as  well. This  is  new   turf !   Please   someone  rescue  me.    quahog   from  cape  cod
ri702bill
OK - are the three deck spindles original?? What size - 3/4" or 17MM ?? Does it have the curved 3 semicircle "recycler" insert near the blades. Both are helpfull to ID it correctly...
Being from RI.....  I thought "Quahog" was in RI, not the Cape... (if you watch "Family Guy")...:laughing-rolling:
  • Haha 1
gwest_ca
Mower DNA 42" side discharge
1966-1967 model RL-426 replaced by
1968 model 5-1421
1969 model 5-1422
1970 model 5-1423
1971 model 5-1000
1971-1972 model 5-1001
1973-1974 model 5-1010
1975 model 5-1011
1975 model 5-1012
1976 model 65-42MS01 - Online Toro parts illustration is the 48" SD deck
1976 model 65-42MS02 - Online Toro parts illustration is the 48" SD deck
1977 model 75-42MS01 - These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded (Do not have operator manual)
These decks all use blades with a 3/4" center hole.
1977 model 75-42MS02 replaced by (Do not have operator manual)
1978 model 85-42MS01 (Do not have operator manual)
1979 model 95-42MS00 (Do not have operator manual)
1979 model 95-42MS01 (Do not have operator manual)
1980 model 05-42MS01 (Have operator manual)
1981-1983 model 05-42MS02
1984 model 05-42MS03 - Last year for bearings with 3/4" ID
1985 model 05-42MS04 - First year for bearings with 17mm ID unless older spindles were updated.
1986-1988 model 05-42MS05
1989 model 15-42SC01
1990 model 15-42SC02
1990-1992 model 15-42SC03
1993-2007 and 2009-2012 model 78345 - These decks all use blades with a 3/4" center hole.
Mower DNA 42" rear discharge
1976 model 65-42MR01 replaced by - (Has the flat spindle belt idler pulley mounted on a triangular plate.) - (Has multi-link hardware at the gauge wheel support)
1977 model 75-42MR01 - Both use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. (Has the flat spindle belt idler pulley mounted on a triangular plate) - (Has multi-link hardware at the gauge wheel support)
These all use blades with 3/4" center hole.
1977 model 75-42MR02 replaced by - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1978 model 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1979 model 95-42MR01 - No ipl available
1979 model 95-42MR02 - (Has no multi-link hardware at the gauge wheel support)
1980-1983 model 05-42MR01
1984 model 05-42MR02 - Last year for bearings with 3/4" ID
1985 model 05-42MR03 - First year for bearings with 17mm ID unless older spindles were updated.
1986-1988 model 05-42MR04
1989-1990 model 15-42RC01
1990-1992 model 15-42RC02
1993-2012 model 78350
Note - 17mm is .669"
ri702bill
Can you ID it from thr chart above??
CCW
Having grown up in RI quahog (pronounced coh hog, not quah hog) is the only name for a hardshell clam.  Love em raw on the half shell.
adsm08
Do you know Peter Griffin?
  • Haha 3
CCW
Can't say I do.
Lee1977
The old Double D decks have a 3/8" bolt and cupped pressure washer on both the blade and pulley. The 3/4 keyed decks have 3/4" nut on both. The newer Metric decks will have a 5/8" nut on the pulley.
Once you locate the right type there isn't a lot of difference in those models.
peter lena
@quahog my wife's uncles  would always have at least one WW2  us navy , deep  cooking vats , with bubbling pork fat , for anything fried , it was to die for , the collective tastes , were amazing . family get togethers , were a regular hands on  set up . always had the kids covering the elders  table set up , and anything they wanted , like a regular production . would usually  start on the grille , BIL take over about  45 min later , everyone would bring family favorites , we totally cleaned up and secured   all of it before leaving , ice cream desert cake , and a nap , pete
quahog
quahog
It  would  be  easier  knowing  the  tractor  year.  I  assume  the  deck  was  purchased   along   with   the tractor    a  314 - 8   serial #  8901078 .   thus   making   the  manual  selection  easier .  I  can  print   it from   there using  the  list provided.  quahog
