Similar Content
By cJ_3D
Hello helpful Wheel Horse enthusiasts!
Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
So referencing this image here from the service manual for the mower deck (37"):
What exactly am I doing with this adjustment knob and how does it fit into this piece?
Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
Much obliged for the help!
CJ
By Rob R
Hi Guys my C81 has a 38 dual blade, side discharge mower deck (# 0537SC01) The deck belt also goes around the mandrels through the mule drive and also to the PTO so it's a huge belt. The current belt is stretched and ready to go. I believe it is around 1/2 X 142 inches but not sure was hoping one of you might have the correct size. Much appreciated. Rob
By drewd
Hi All, I have a 71 or 72 Model # 101006, Serial # 790336. Model number chart says 71 but the paper for the engine has a print code 72. The closest I could find was for models 1-3745 & 1-3741.
Two questions. I finally need to replace the drive belt. This manual list the belt as # 1576.
Two questions:
1) Does anyone know what size that translates to? I do have the old belt but the inside edge is falling apart so it will measure a little longer than it should.
2) This tractor has the electric clutch. What is the best way to remove the belt?
As always...Thanks!
By Wheel Horse Willy
Hey all!
New to the page so first, thank you for the add! I’ve been a Wheel Horse fan for over 20 years since my old neighbor and his grandfather got me hooked! After many years of searching, I finally got a hold of a real one! I did have a Toro-Wheel Horse….212-? It was a good machine but gave it to a friend for a back up. I picked up a 1988 , 252-H and it’s clean! A little rust but the red shines up nice! Everything is original. Belts, tires, bulbs….fuel line and filter have been replaced. I started cutting my lawn the day I brought it home and since my yard is a little hilly, thought maybe the sensor under the seat was the culprit for the stall but it seems to depend how warm it is out? I managed to cut the entire back yard today and just as I was pulling it into the shed, it sputtered and died. It fires right up and runs great when cold! Even seems fine after a while running but after reading a few posts, I might try to replace the spark plug. The one thing I did not check. This was an issue with a 20+ year old Echo weed wacker I had so I will try that. If anyone has any other ideas/info, I would appreciate it! Thank you and have a great evening!
By MachXXII
Does anyone know what battery a 1988 252-H needs. I looked around and couldn’t really find an answer. Thanks
