876wheelhorse
10 hp kohler
876wheelhorse
looking to put a 10 hp in a short frame. i have a 876. was going to move the engine over half inch so the pulleys line up for the belt. i was just wanting to know if anyone has done it. is there something i am missing to modify. let me know also looking for a complete running engine in nw ohio ne indiana sw mich. willing to travelfor one
Kelly
The factory did it in 65, on the 1045, 1055 and 1075, to keep it all under the hood you will need a small base engine block, and a short oil pan, if you move the engine to the side you will have to modify the hood even with the short pan, the factory used a diff, belt guard, and trans pulley and clutch pulley , and a few other special parts for the swap, so yes it can but done.
Kelly
Oh by the way I probably have most of the parts even a engine for the swap, I'm in lower MI.
876wheelhorse
ok where are you in lower michigan? i go up to coldwater about every weekend. let me know
