fireman29
engine
fireman29
:scratchead: hi everybody ! i was woundering what kind of engine goes on a ride away jr rj-35 1956 . i got mine since i was a kid but the engine was replace :hide: . any help would be appreciate thanks in advance...
Rod(NASNUT)
I see 2 engines Kohler K-90 3.5 HP or a Clinton B-1200 3.6 HP.
fireman29
:scratchead: hi ROD, thanks for the reply is there a way i can be sur which one goes on it ???
Rod(NASNUT)
If there is a way I don't know :hide: I would think they made them with both :scratchead:
MikesRJ
:scratchead:
If your machine has a serial number you might be able to find out, but either engine is "correct" for that model and year.
The Clinton B1200 Manual can be found here: Clinton Service Manual
The Kohler K90 manual can be found here: Kohler K90 IPL Manual
I don't have a picture of the Clinton, but the Kohler K90 looks similar to these two engines ....
VinsRJ
Here
MikesRJ
:hide: NICE! :ychain:
When will you put that polished recoil on it? That's what I am waiting to see! :scratchead:
VinsRJ
Working on getting there. Tonight I'm hoping to install the head and bore tins. Then to the ignition. Then....... bla, bla, bla, you know. :ychain:
