Wayne0 455 #1 Posted June 18 I'm looking for the colored prints for an '84 Work Horse GT1800 Automatic Mo# A1-18BE01. It won't start (turn over) after replacing a hose from the pump to the valve. PO bypassed all safety switches except the brake. TIA. 1 Share this post Link to post Share on other sites
c-series don 8,688 #2 Posted June 18 If you go to our manuals section you will find the electrical schematic there. Someone here that’s better than me at this stuff can probably post a link to it. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,040 #3 Posted June 18 23 more in general search https://www.wheelhorseforum.com/search/?q=A1-18BE01&quick=1&type=downloads_file 2 Share this post Link to post Share on other sites
Wayne0 455 #4 Posted June 18 Thank you. We'll see what shakes out. 2 Share this post Link to post Share on other sites
ebinmaine 67,420 #5 Posted June 18 9 hours ago, Wayne0 said: Thank you. We'll see what shakes out. When we rebuilt the GT1800 for our friends I found some of the wires were faded to white unless the covering could be peeled. As per my usual SOP/ MO I yanked most of the old stuff out and started from scratch. Share this post Link to post Share on other sites
Wayne0 455 #6 Posted June 19 (edited) Not a bad idea, Eric. Not happening in this heat though. Tractor is half apart in the yard where it died after blowing a hydro line. Oil every where (in my shoes too) . Had one made local, but the ends were kind of cobbled together. Tight fit, but it worked. De-greased it today. We'll see what tomorrow brings. Good opportunity to change the oil in the tranny too, as half is gone anyway. Edited June 19 by Wayne0 1 Share this post Link to post Share on other sites
ebinmaine 67,420 #7 Posted June 19 6 minutes ago, Wayne0 said: Not a bad idea, Eric. Not happening in this heat though. Tractor is half apart in the yard where it died after blowing a hydro line. Oil every where (in my shoes too) . Had one made local, but the ends were kind of cobbled together. Tight fit, but it worked. De-greased it today. We'll see what tomorrow brings. Good opportunity to change the oil in the tranny too, as half is gone anyway. On the plus side your feet are well lubricated and soft and supple. Share this post Link to post Share on other sites
Wayne0 455 #8 Posted June 19 1 minute ago, ebinmaine said: On the plus side your feet are well lubricated and soft and supple. 1 Share this post Link to post Share on other sites
Wayne0 455 #9 Posted June 20 OOK, After 5 hours of chasing wires as well as mechanical issues, O'l Rusty is back on his feet (wheels). I found several chafed wires as well as cobbled together connections.(tape!) The main issue was the brake interlock switch is bad. Bypassed for now as the lawn looks like a hay field. Ignition switch is getting sketchy too. Doesn't always spring back to "run" from "start". Ignition switch should be easy to source, not so sure about the brake switch. I may have to get creative. 1 Share this post Link to post Share on other sites
ebinmaine 67,420 #10 Posted June 20 17 minutes ago, Wayne0 said: Ignition switch should be easy to source, not so sure about the brake switch Double check the part number of the ignition switch and order a good name brand. I've had several "cheapoes" last a year or whatever and go bad. Stens is often the same switch as factory for less but even a Toro switch is less then $25. The brake switch.... well ours wasn't on when we got the GT1800 and it's still out. There's NO kids or inexperienced riders. Share this post Link to post Share on other sites
Wayne0 455 #11 Posted June 20 I will say, I'm the ONLY one using this tractor. I'd leave the brake switch out, but knowing ME something bad will happen! I'm going to fill the oil back up and run it for a while before changing. The old oil was a tiny bit milky, so the new fill should dilute that before a full change and filter. What are you using for a filter? 1 Share this post Link to post Share on other sites
ebinmaine 67,420 #12 Posted June 20 Wix 1410 Or Napa GOLD 51410 Same filter. Baldwin is also a good brand. BT8486. Don't use fram.... Share this post Link to post Share on other sites
Wayne0 455 #13 Posted June 20 Thank you for that. 1 Share this post Link to post Share on other sites
