SnoJet
No power to coil
SnoJet
Hello and thank you for any help. My 416H lost power to the coil. It will turn over but will not start. If I run a jumper wire from the battery to the coil post it will start and run fine. I have checked and bypassed the seat and PTO switches. Any other advice?
gwest_ca
Model number and serial number would help.
SnoJet
model 73421
serial 3900541
gwest_ca
Download this file. One schematic shows what is required for ignition.
ri702bill
I believe that the 416H has that troublesome-over-time 9 pin connector...... probe the coil power wire on both sides of the connector with the key "ON"
SnoJet
Bingo! 9 pin connector was the culprit. Pulled it apart and reconnected and it works! Thank you!
  • Excellent 1
Lane Ranger
You also have to watch for gnawed coil wires under the tins from
mice.   I had a 314 with that problem!  Just had to purchase a new coil.
