ebinmaine 67,498 #1 Posted June 16 We'll be installing LIGHT DUTY wooden shelves in the new workshop space soon. How far apart VERTICALLY do you have your storage shelves? And why? I'm thinking of a variable setup with most being either 20" or 15". The distance is center to center with a 3/4 thick shelf so say 19"+ and 14"+. Thoughts comments questions suggestions? Share this post Link to post Share on other sites
rmaynard 15,459 #2 Posted June 16 I found that the minimum space should be no less than 2" more than a large jug of oil or anti-freeze. 3 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,318 #3 Posted June 16 Are you going to use plastic totes on the shelving? Measure height of those and add a couple inches. 3 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,330 #4 Posted June 16 2 minutes ago, Sparky said: Are you going to use plastic totes on the shelving? Measure height of those and add a couple inches. Always a good idea to keep critters out. 3 Share this post Link to post Share on other sites
ebinmaine 67,498 #5 Posted June 16 1 minute ago, Sparky said: Are you going to use plastic totes on the shelving? Measure height of those and add a couple inches. Not on these particular shelves. All loose stuff storage. They'll be only 8" deep on a 2 x 6 stud wall. Excellent point though. Share this post Link to post Share on other sites
ebinmaine 67,498 #6 Posted June 16 Just now, stevebo said: Always a good idea to keep critters out. Definitely helps. Most of our camping gear is stored in totes. Share this post Link to post Share on other sites
953 nut 55,229 #7 Posted June 16 I like 18" on center for general stuff shelving. I use gallon paint cans to store small stuff, no critter get in and small enough that they don't become a catch-all. 2 1 Share this post Link to post Share on other sites
ri702bill 8,321 #8 Posted June 16 Staggered height - 20 at the bottom, then 16, then 12 ??? 2 Share this post Link to post Share on other sites
formariz 11,987 #9 Posted June 16 I always found that today’s preferred distances will change in future due to different needs. That is the reason why I always use heavy duty adjustable Garcy standards. Pricey but unlimited adjustability with actual standards and brackets taking a minimal amount of space. 2 Share this post Link to post Share on other sites
ebinmaine 67,498 #10 Posted June 16 25 minutes ago, ri702bill said: Staggered height - 20 at the bottom, then 16, then 12 ??? Here's my current thought process: The Pole Barn floor is roughly 2" lower at the front. The upper beam is level. The floor to beam distance is 84 3/4 at the back. The shortest usable distance. Using an available spacing of 84"... 24"+ from floor so larger items can be stored. Engines, transmissions, boxes of materials etc. 60" usable with lowest shelf at very bottom. (24" off floor) Shelf distances, Every other stud set: 3 shelves starting at 20" from TOP. 20", 40", 60" down from top. Window pockets are 19.5" from TOP. (Shelves beside windows could be fastened to bottom of window frame and set at 19.5") Or: 4 shelves at 15", 30", 45", 60" from TOP. 2 Share this post Link to post Share on other sites
CCW 1,295 #11 Posted June 16 A concrete floor is like a sponge if you have damp conditions. I would want any transmission or engine siting on something to help keep the underside dry. 1 Share this post Link to post Share on other sites
ebinmaine 67,498 #12 Posted June 16 10 minutes ago, formariz said: I always found that today’s preferred distances will change in future due to different needs Definitely agreed. We've found that many times here over the last few years. I'd like to have adjustment here n there but these shelves are being made of leftovers from the barn siding. That's why I'm trying to get a reasonable distance with some good variability. I'd rather have 1 less shelf per vertical space than have extra shelves that aren't right. Share this post Link to post Share on other sites
CCW 1,295 #13 Posted June 16 Other thought is one shelf should be at least notebook high plus an inch or two. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,498 #14 Posted June 16 Just now, CCW said: A concrete floor is like a sponge if you have damp conditions. I would want any transmission or engine siting on something to help keep the underside dry. True. Ours are stored on small wheeled dollies. Highly advised. Share this post Link to post Share on other sites
WHX?? 48,815 #15 Posted June 16 Shelving is like a horse barn ... never big enough or have too many.... 2 1 Share this post Link to post Share on other sites
oliver2-44 9,750 #16 Posted June 16 Spacing them all at 20" or even 15" seems to waste some space. I find a 20" bottom, then 1a 14 or 15, and the rest 12. As you get higher, your not putting anything super heavy on its.. Especially with only 8" wide shelves. I have 2 8ft high shelf cabinets. One has 14" and the other 16" wide shelves. They work great. 1 Share this post Link to post Share on other sites
ri702bill 8,321 #17 Posted June 16 5 hours ago, CCW said: A concrete floor is like a sponge if you have damp conditions. I would want any transmission or engine siting on something to help keep the underside dry. OR - wrapped tightly in plastic, with a rust inhibitor inside the bag.......... 2 Share this post Link to post Share on other sites
ebinmaine 67,498 #18 Posted June 16 Well folks here's what we did today. 3 sets out of 20. These are 15" spacing, starting from the top down. 1 Share this post Link to post Share on other sites
ri702bill 8,321 #19 Posted June 16 Good - the blocking allows for removal to "adjust" the spacing..... 2 Share this post Link to post Share on other sites
ebinmaine 67,498 #20 Posted June 16 48 minutes ago, ri702bill said: Good - the blocking allows for removal to "adjust" the spacing..... Absolutely. Our workshops have been a variable space as needed for years. 2 Share this post Link to post Share on other sites
