pjjack77@msn.com 0 #1 Posted June 12, 2024 My 520H when placed in forward it goes about 5 feet stops. It will back up the same distance and stop. when it stops in either direction it squels like a belt slipping. It had been mowing really well up to that point. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,240 #2 Posted June 12, 2024 Sounds like you have a worn drive belt. Pull the cover off and see. Adding Jack the back up a see how far you can turn the rear wheels. If it is almost one complete turn you may have a broken bolt in the differential. Don't force it and break something. 4 Share this post Link to post Share on other sites
Ed Kennell 40,444 #3 Posted June 12, 2024 (edited) Five feet is about one rear tire rotation. Sounds like something is jamming the differential. Check the dipstick. Is the bottom end missing? Jack up both rear wheels. Spin one forward by hand. The other one should spin backwards. Edited June 12, 2024 by Ed Kennell 3 Share this post Link to post Share on other sites
oliver2-44 10,351 #4 Posted June 12, 2024 Looks like they have you on a path to check things out. Lots of friendly help here, so don't be hesitant to ask questions. 1 Share this post Link to post Share on other sites
