Kelsey 91 #1 Posted June 11, 2024 Greetings, What drive belt from Amazon can I order for my son's 310-8 wheel horse 2110K806? Thanks to all who reply, Kelsey Share this post Link to post Share on other sites
daveoman1966 3,807 #2 Posted June 12, 2024 (edited) Which belt? Trans drive belt? (#7473) PTO to deck belt? or the Deck spindle belt?? Edited June 12, 2024 by daveoman1966 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #3 Posted June 12, 2024 Transmission drive belt 78-7100 replaced by 7473 - HB x 81.9" or 5/8" x 81.9" 2 Share this post Link to post Share on other sites
Ed Kennell 40,453 #4 Posted June 12, 2024 This is the transmission drive belt I use on my 310-8. Around $30 at TSC. 2 Share this post Link to post Share on other sites
Kelsey 91 #5 Posted June 12, 2024 Ended up buying a GATES B79 21/32" x 82" belt at a local NAPA (32 bucks and change). That certainly was an entertaining afternoon working on that WH. Nothing wrong with some physical therapy to set things right. About 10 inches or so to the right of the clutch pulley, when I gently pushed down on the old belt it flexed at least 2 inches. In the same spot, the new belt may flex about 1/2 inch. Thanks again, Kelsey 1 Share this post Link to post Share on other sites
Kelsey 91 #6 Posted June 21, 2024 On 6/12/2024 at 5:36 PM, Kelsey said: Ended up buying a GATES B79 21/32" x 82" belt at a local NAPA (32 bucks and change). That certainly was an entertaining afternoon working on that WH. Nothing wrong with some physical therapy to set things right. About 10 inches or so to the right of the clutch pulley, when I gently pushed down on the old belt it flexed at least 2 inches. In the same spot, the new belt may flex about 1/2 inch. Thanks again, Kelsey UPDATE: Although I installed this belt that day, I got preoccupied with other duties in my life. Today, I started up the wheelboy and all kind of problems started at the same time. Mind you this all took place within 30 seconds or so. The belt started smoking and I couldn't place it in 1st gear low because the gears were grinding. I shut the tractor right off. (I can proudly say in the 38 years I've owned my wife's wheel horse, I've always taken my time and gently put the tractor in gear. This all due to the Wheel Horse dealer who showed me how to place it in gear when I bought our 1974 C-100 from him.) It appeared the drive belt's height was causing the problem because it was rubbing on the idler pulley assembly. I took the belt off and put the old one back on without any problems. Also, I returned the belt to CarQuest and not to NAPA as I originally typed. I learned my lesson instead of being lazy, I'll just visit the local Toro dealer and pay the premium price for parts. I'll let you know how it goes. Kelsey 1 Share this post Link to post Share on other sites
Ed Kennell 40,453 #7 Posted June 21, 2024 (edited) 45 minutes ago, Kelsey said: The belt started smoking Something smells fishy er smoky here. Got any pictures of how the belt was installed? The belt should not be moving when the clutch is depressed. Here is a video of a 310-8 Idler pulley and belt operation. Edited June 22, 2024 by Ed Kennell 2 1 Share this post Link to post Share on other sites
Kelsey 91 #8 Posted June 22, 2024 Today, I called the local Toro dealer and they said," It'll be next Thursday (46 bucks and change). Let me call you back if I need to. I just remembered that I had a drive belt from my dismantled C-100. Ten minutes later, the donor belt was in. Now, you remember the Mounds candy commercial jingle? Sometimes you feel for a nut, some- times you don't. I substituted the name dolt in place of nut. Sometimes I feel like a dolt.... keep reading. I stood back and went through my mental check list. It finally dawned on me that the drive belt was under the running board/brake pedal support. By now, I'm getting pretty good at taking this apart and putting it back together. Finally, I started it up without any problem. The 1st belt must have been under the support. I panicked too quickly when it wouldn't go into gear along with the smoke. Also, I didn't do a mental check list. I tend not to think clearly when I'm in 90' weather tinkering on a WH tractor. I still enjoyed myself through it all. 1 1 Share this post Link to post Share on other sites
kpinnc 13,704 #9 Posted June 24, 2024 On 6/21/2024 at 7:56 PM, Ed Kennell said: The belt should not be moving when the clutch is depressed. Outstanding video! Short and to the point. No way on earth to scribble out how that belt stop should function. Share this post Link to post Share on other sites
kpinnc 13,704 #10 Posted June 24, 2024 On 6/22/2024 at 7:24 PM, Kelsey said: I tend not to think clearly when I'm in 90' weather tinkering on a WH tractor. Same for me but at any temperature! Share this post Link to post Share on other sites
