MSBiker 46 #1 Posted June 11, 2024 I am struggling to remove a leaking axle seal on my Lawn Ranger. Now that I have it tore up good trying to remove it, I have to replace it now. Anybody have a good method short of tearing down the transmission? I assume this seal is original to the machine. It is really stuck in there. Share this post Link to post Share on other sites
ebinmaine 75,689 #2 Posted June 11, 2024 Is this the same basic transmission as the larger models? Share this post Link to post Share on other sites
Handy Don 15,132 #3 Posted June 11, 2024 13 minutes ago, ebinmaine said: Is this the same basic transmission as the larger models? Lawn Ranger transmission is the usual 3-speed 1 Share this post Link to post Share on other sites
ebinmaine 75,689 #4 Posted June 11, 2024 1 minute ago, Handy Don said: Lawn Ranger transmission is the usual 3-speed On thanks Don. 17 minutes ago, MSBiker said: Anybody have a good method short of tearing down the transmission? I use a 1/4 blade flat screwdriver 🪛 about 8" to 10" long. The length makes it easier for ME to work around the axle. I pretty much do a smash crunch crush around the outside of the seal where it meets the transmission case. You're removing the seal. Not trying to save it. It'll rotate some but that doesn't matter. Eventually the seal will loosen up and keep rotating. Just slide the seal right off the axle at that point. 1 Share this post Link to post Share on other sites
MSBiker 46 #5 Posted June 11, 2024 (edited) Thanks, I've be jambing picks into the seal and trying to hook the edge with no joy. I will sharpen up a flat blade screwdriver and see if I can get it between the body and the housing. Edited June 11, 2024 by MSBiker 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #6 Posted June 11, 2024 (edited) Remember that the seal is only 1/8" thick. Don't dig too deep. Edited June 11, 2024 by stevasaurus 2 3 Share this post Link to post Share on other sites
ebinmaine 75,689 #7 Posted June 11, 2024 1 hour ago, stevasaurus said: Remember that the seal is only 1/8" thick. Don't dig too deep. Excellent point!! Share this post Link to post Share on other sites
