Dave the Farmer
Starter Motor will not disengage
Dave the Farmer
I have a Toro Wheel Horse Model  73429   Serial #8901097,  314–8 Garden Tractor . I was mowing for 4 hours yesterday, and when I turned off the ignition, the engine stopped but the starter motor continued to hum and would not disengage until I finally disconnected the battery. What can I do to solve this problem.
Sparky
  That sounds like a bum ignition switch or the solenoid has “stuck” closed.
  If you reconnect the battery does the starter engage?
:WRS:
Dave the Farmer
Thanks Sparky! When I reconnected the battery, the tractor attempted to start so I disconnected it again.
gwest_ca
Sure it is not a model 73448?
Dave the Farmer
The Model # is actually 73428, Serial #8901097. Sorry for the confusion.
gwest_ca
So it is a 312-8 model
Dave the Farmer
Thanks for the wiring diagram.
953 nut
:text-yeahthat:
Bad interlock relay or ignition switch, relays seldom go bad so it is probably the ignition switch keeping the interlock relay and kill relay energized.
rwmastel
@gwest_ca
Doesn't his serial number mean it's a 1989 model year?  You keep posting newer 1998 documentation.
953 nut
6 hours ago, rwmastel said:
@gwest_ca
 1998 312-8 Early model73428
gwest_ca
With this type of serial number you reverse the first two digits to get the model year.
Up to and including 1989 the hood decals had a maroon background.
In 1990 on the hood decals had a black background.
