SPINJIM 1,981 #1 Posted June 3 I'm rebuilding a K91 engine, and would like to replace the oil seals for the crank shaft, both output and bearing plate sides. I checked the old threads for info, but those references were all out of date and discontinued. Anyone have new sources or numbers for those seals. I'd love to have a NAPA equivalent, because I can get that in a day or two. Thanks for any help. Jim Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,078 #2 Posted June 3 You need original part numbers For engine model number enter K91-xxxx in the box replacing the x's with the spec number. https://www.partstree.com/search/?msclkid=e5baf37065dc11af43e5a9808bdc6a14 Post your spec number so we can follow along. Share this post Link to post Share on other sites
squonk 41,219 #3 Posted June 3 PTO side either a Napa 8796 or 7440 depending on spec # Flywheel side Napa 8677 1 1 Share this post Link to post Share on other sites
SPINJIM 1,981 #4 Posted June 3 Spec # K91 RT 561255B, spec. 31459A. Came off of a Sno-Flyr made by Eska. I plan to but it on a WH 604. Share this post Link to post Share on other sites
