Marv
Mounting tiller 07-36TL01 on 321-8
Marv
Little background first. I have had this tiller a long time (probably 20, 25 years and used it on a C series tractor. Quite a looong time age I quit using it. I removed all the hitch system from the tractor. Well that is simple (maybe). I hung the parts on the wall. Well that should tell me take it and go. Not so fast. I had two other tractors with the implement hitch on them. I had removed all that from them too. Now the problem (memory). I installed a system on the 310 to lift the tiller, and it does. Now here is the thing I can't remember. What is the length, number of links of the chain that attaches to the tiller for lift. I have more than one chain because of the other hitches.
Marv
gwest_ca
These manuals will demonstrate what is required
Marv
Thank you for the info.
Marv
