michael hillenbrand 2 #1 Posted June 1, 2024 the clutch will not stay in the disengaged position any help would be greatly appreciated Share this post Link to post Share on other sites
Pullstart 68,521 #2 Posted June 1, 2024 Are you referring to the brake pedal that returns the linkage to center? There is a return spring in the tunnel that often breaks. Share this post Link to post Share on other sites
michael hillenbrand 2 #3 Posted June 2, 2024 no its the little handle that lifts the idler pulley off the drive belt 1 Share this post Link to post Share on other sites
23 Reo 232 #4 Posted June 2, 2024 I had the same problem on my 81 C-125 automatic. I think it is a common problem with the early black hoods. Sorry, I do not have a solution. I just thought it was worn out and did not use it. Do not trust it. The handle is likely to drop and your tractor could take off. Share this post Link to post Share on other sites
squonk 44,860 #5 Posted June 2, 2024 Pivot holes and pin wear out on the lever thingy. I took one to my welder buddy and he repaired the hole and made a new pin. 2 Share this post Link to post Share on other sites
953 nut 62,992 #6 Posted June 2, 2024 Mike @squonk has it right, the round hole becomes an oval and there is too much play. Share this post Link to post Share on other sites
michael hillenbrand 2 #7 Posted June 2, 2024 ok thank you all very much i thought i was missing some parts Share this post Link to post Share on other sites
squonk 44,860 #8 Posted June 2, 2024 1 hour ago, michael hillenbrand said: ok thank you all very much i thought i was missing some parts Well maybe you are. Without pictures we can't tell. but if everything is there and the pivot is worn, it will flop around and wear out the belt faster and rattle a lot. Share this post Link to post Share on other sites
michael hillenbrand 2 #9 Posted June 2, 2024 i will get some pics and upload them thank you Share this post Link to post Share on other sites
