rjg854 11,882 #26 Posted August 3, 2024 12 hours ago, Steve Janninck said: Once again I apologize for covering something already explored NO, thank you for your post and the breakdown of the parts. Any and all information is great and helping us to make wise decisions when repairing our equipment. 2 Share this post Link to post Share on other sites
Lee1977 7,041 #27 Posted August 4, 2024 You need to put a good coat of epoxy paint on the housing to keep the acid from eating away at them. 1 1 Share this post Link to post Share on other sites
Anvil 9 #28 Posted August 12, 2024 On 8/2/2024 at 8:38 PM, Steve Janninck said: Toby, Thank You for sharing this with us. Here I thought I was helping review a new item to the market and you are 400 hours in. I apologize for my posts today since the water is all ready under the bridge. I was going to install the spindles and test them, but you have that done for us. Great to hear they I working well, I see no major difference between the OEM and the 8TEN. Sorry to all for the waste of bandwidth! I meant well, and just thought it was an economic benefit. Heck at least maybe more know they are available! Once again I apologize for covering something already explored. I am relatively new here, and will do more research before making a post. Steve Hello Steve. I sincerely appreciate all this information as I too have two 48" and two 42". I am wondering what to do with the center dual groove pulley as mine is very rough and I'm guessing when I go to pull it off I will destroy it. Any thoughts on the dual pulley replacement? Anvil Share this post Link to post Share on other sites
Wvtroutbum81 233 #29 Posted August 12, 2024 Just put 3 of these on my 42” SD model 78345 all of the pulleys are wrong, they all came the same size and not double pulley Share this post Link to post Share on other sites
Steve Janninck 171 #30 Posted August 12, 2024 43 minutes ago, Anvil said: Hello Steve. I sincerely appreciate all this information as I too have two 48" and two 42". I am wondering what to do with the center dual groove pulley as mine is very rough and I'm guessing when I go to pull it off I will destroy it. Any thoughts on the dual pulley replacement? Anvil Anvil, The pulleys that come with the spindles although nice were the wrong dimension, too large. I do believe they sell the same spindle with a smaller pulley but can’t confirm the dimensions On my deck, I had the same problem as you do. The double pulley was worn so thin that it was impossible to continue use. I bought 2 separate pulleys at McMaster Carr and machined the cores so the two pulleys could have the separation as the original. They are not keyed, just sandwiched by the nut. Have not had any issues since installing them. The pulleys seem to be made out a heftier material than what I took off. Many pulleys fit that shaft dimension. I was thinking of trying to increase the blade speed with a smaller drive pulley. I might play around with that! Hope this helps. Steve 1 Share this post Link to post Share on other sites
Anvil 9 #31 Posted August 13, 2024 Thank you Steve. I was concerned with what came with the new spindles but haven't had a chance to take measurements. Thanks for the tip on McMaster Carr. I forgot about them. Is the center spindle shaft any different than the end shafts in length for the double pulley? Thanks again. Anvil 1 Share this post Link to post Share on other sites
Steve Janninck 171 #32 Posted August 13, 2024 20 minutes ago, Anvil said: Thank you Steve. I was concerned with what came with the new spindles but haven't had a chance to take measurements. Thanks for the tip on McMaster Carr. I forgot about them. Is the center spindle shaft any different than the end shafts in length for the double pulley? Thanks again. Anvil Anvil, All of the spindles have the same length shaft. The spindle shaft has a long reach on the threads. Long enough to handle 1 or 2 pulleys. On a single pulley spindle, the nut goes way down the threaded shaft. On a double pulley the nut parks towards the top of the threaded shaft. All are 5/8 inch for the drive side.. Hope this helps, Steve 1 Share this post Link to post Share on other sites
