Lane Ranger
New mower deck spindles from 8TEN Company
Lane Ranger
Have any Red Square members purchased these spindles from  a new company called 8TEN. ??   They are selling these on eBay. -a set of three at about the price of one new Toro spindle??
They appear to be selling with all the related parts according to their pictures posted on the eBay advertisement.
  • Like 5
Skwerl58
I ordered one of their replacement spindles for a Troy Bilt ZRT and it looks and operates well. Only time will tell about the qualty of the bearings, shaft and overall endurance of them.
  • Like 4
Vintage_Wheel_Horse_Lover
did you order them? if so keep me updated. I have a 42inch deck off a b100 and its been down for 3 or so years because I didn't wanna pay that much for a 150ish per spindle when I needed all 3. when I had other mowers to use. because 450 for spindles is Alot when your 17 or 18. but I could afford that set if they're decent
Lane Ranger
I did not order them but I believe I will!
This is the  response I received from 8TEN customer service:
Hello and thank you for reaching out.
Yes, the pulleys are included as well as any part shown in the photo. If you'd like us to determine fitment, I would the full model number and serial number of your machine. Once you send us the information, we can confirm correct fitment for your specific machine.
Attached below is a reference picture showing what the possible model/serial/PIN tags can be so you know what to look for.
Best regards,
Bria
spindles, pulleys and all the pictured parts for this price is worth the money 💰 as far as I am concerned!
Lee1977
I have a 75-48MS01 the only difference between the 48 and 42 spindles is the pulleys and blades. I had Double D,, 3/4 Keyed, and  now have metric spindles on it.
I might order a set I have a 1989 42 deck that the spindle housings were bad when I got it.
Wvtroutbum81
Any update on these
Bill D
Based on the picture I think you'll need to reuse your center pulley.  Hopefully it fits.
Steve Janninck
Posted (edited)
Lane,
I took the risk and ordered a 3 pack through Amazon, same price, free shipping.
I was very happy to see what arrived. I do not have a spare original spindle to get accurate measurements from, so I may have to see if anyone can take dimensions off of a WH/Toro Spindle for comparison.
Purchased a set of 3 old WH units out of the classifieds, but they have not arrived yet for disassembly.
Pictures and Comments are on the way!
Steve
Edited by Steve Janninck
Added Pictures
  • Excellent 3
Steve Janninck
This is what comes in the box.
The sealed bearings are PN 6203RS, not sure of the quality in the long run, but seem to roll like a Timkin / SKF. The lower bearing is locked in with a snap ring.
  • Excellent 6
Steve Janninck
I disassembled the spindle. Removing the lower bearing, I was surprised to find that the seals on the inside of the bearings were already removed. This allows the grease that comes from the zirk fitting to actually get to the bearing! Most new spindles I have worked with all seem to have seals on both sides of the bearing.
  • Excellent 5
Steve Janninck
Upper bearing and flange. The housing even has the 3 little centering nubs in the casting for installing in the deck.
  • Excellent 3
Steve Janninck
Blade attach area and nut dimensions.
  • Excellent 2
Steve Janninck
Upper pulley attach nut.
  • Excellent 2
Steve Janninck
Total shaft length not including the grease zirk is approximatey 7 3/8 inches. The shaft hold hex is 1 1/8 inches.
  • Excellent 2
Steve Janninck
Posted (edited)
Shaft collar at lower bearing and pulley shaft dimensions.
No key way in the pulley or shaft.
Added comment
  • Excellent 2
Steve Janninck
Pulley dimensions. One side of the center flange is flush and the other side extends out about 3/16 of an inch.
  • Excellent 2
Steve Janninck
Casting looks great. Not sure how to qualify the quality. It’s so nice to see housings without corrosion craters! I do think I will get the housing either powder coated or maybe POR 15.
  • Excellent 5
Lane Ranger
Wow!  They look great to me snd that price is a real plus!  Thank you Steve for the complete coverage!
  • Excellent 2
EB-80/8inPA
It would be great to hear a follow up on how they performed and, eventually, their durability.  Thanks for posting.
Steve Janninck
Posted (edited)
For less than 50 bucks, I hope this will give more life to the WH Mower Decks.
These 3 will keep me going for quite some time!
If you look at the 8Ten website they also have spindles for the 36 /42 in rear discharge decks, similar design but maybe shorter in height, and smaller diameter pulleys.
36 / 42 Rear Discharge w smaller pully
added URL
  • Thanks 2
Toby Stockman
They work great i put 3 brand new ones on my 48'' deck and its been about 400 hours sense i put them in very nice product would highly recommend and holding up great!!
  • Like 4
  • Excellent 2
Wayne0
The bearings with no seals on the inside allow you to fill the spindle with grease through the zerks and have lube there constantly.
  • Like 5
Steve Janninck
Toby,
Thank You for sharing this with us. Here I thought I was helping review a new item to the market and you are 400 hours in. I apologize for my posts today since the water is all ready under the bridge. I was going to install the spindles and test them, but you have that done for us. Great to hear they I working well, I see no major difference between the OEM and the 8TEN.
Sorry to all for the waste of bandwidth! I meant well, and just thought it was an economic benefit.
Heck at least maybe more know they are available! Once again I apologize for covering something already explored.
I am relatively new here, and will do more research before making a post.
Steve
  • Excellent 2
ebinmaine
Steve
'Tis no apologies need sir!
Your pics and measurements are top notch and appreciated!
Toby Stockman
Yes thank you for sharing the pics they are great the 8ten wheelhorse spindles have been out a couple years i was a dealer for them when the brand just took off i am no longer a dealer but i like all there products spindles, blades, belts, ect and they are a great price and the best thing is they are made out off better aluminum than the wheelhorse ones so they wont be corroded away over the years like the wheelhorse ones do.
