Fordiesel69
Where to get foot rest treads
Fordiesel69
On the 300/400/500 sereis and the older b's and c's there was a rough texture material.  Any idea best place to aquire?
ebinmaine
I've been using skateboard tape for a few years.
Poke around on the internet a little bit and you'll find quite a good many sources. I've even found different colors.
I've also used stair tread tape in the past. Grainger sells that. Uline. Toro.
ri702bill
HFT sells an adhesive backed diamond tread rubber - 12" x 12". One pass thru the table saw gets you 2 pcs 6" or so x 12" Works well.
One of our vendors friends sells the ribbed rubber version...
Edited by ri702bill
lynnmor
Search for "fine ribbed rubber matting" and choose from numerous suppliers.
Fordiesel69
Nope its not ribbed its the black sand coating stuff.
953 nut
rmaynard
AlexR
This is what I used, I cut it in half so 12" long and then cut along the yellow strip discarded the small strips with the yellow on it and used the approx 5x12" pieces as the tread grips it's already got adhesive on it and it's a lot cheaper then buying a big roll of grip tape.
 https://www.menards.com/main/paint/adhesives-glue-tape/tape/tread-tape/skid-guard-trade-6-x-24-reflective-anti-slip-tread-tape/015735674129/p-1444444244318-c-7189.htm?exp=false
Edited by AlexR
