marreque
1054 k241
marreque
Looking to see if anyone has an answer, my k241 has shorted out 2 spark plugs in the last year. Anyone else have this issue??
WHX??
I guess I never heard of a plug shorting out. Fouling out yes.
A pic of the plug will tell us how the motor is burning fuel.
Proper plug? Should be a H-10 champion or equal.
Not overheating cooling fins clean?
Handy Don
Any smoke at start or under load? Black or white?
953 nut
Check the gap of your ignition points, it should be 0.020"    If the gap is not correct yout ignition timing will be off and may result in poor performance and carbon build-up.
marreque
Posted (edited)
Not fouled but complete loss of spark at the plug. Second H10 in 6 months. Change the plug and spark is restored. The first plug was probably 30yrs old and I understand that, but the second is a few months. I’ll post a picture of the plug later.
Edited by marreque
marreque
She doesn’t really smoke to much after warming up. Its original engine and carburetor and really haven’t been touched. Amazing how it still runs as good as it does 59yrs old
  • Like 4
marreque
Yes H10 and no overheating.
Handy Don
A puff of black smoke at start could be from choking. More and the mixture is too rich.
Blue/white smoke is burning oil--not conducive to long plug life.
A mismatched plug could be in the wrong heat range and would work poorly or fail after working for a while.
Pullstart
Sometimes, they don’t make ‘em like they used to,..
  • Like 6
WHX??
Posted (edited)
Especially with Chumponions.
Some guys here don't like them & prefer Autolites. Personally I have never had issues with Chumps.
Says he is using H 10s.
Edited by WHX??
marreque
Well I might as well try an Autolite, maybe it will keep it lit. Anyone know the plug number in Autolite?
Fordiesel69
It outta lite but it don't.
rmaynard
Autolite 216
Wheelhorse#1
Check the points .I had  a similar issue and found the points were cracked.And they were original kohler.
marreque
On 5/31/2024 at 9:21 AM, rmaynard said:
Autolite 216
Thank you
marreque
Just put a fresh Autolite 216 in the Horse. Fired right up, now to see how long it will last.
Thank you gentlemen!
