Mister_520H
Wheel Horse 520H Hydro lift arm
cleat
7 hours ago, oliver2-44 said:
I’ve never had a 520; but I though you had to have the gear reduction steering for  the 60” deck to fit.  If I off base just say so. Did that P.O. mod some how make the deck hang slightly farther back?
You need the forward swept front axle but not necessarily the reduction steering.
The 520HC has the swept axle and standard steering.
I believe the 1990 520H is the same way.
  • Excellent 2
Handy Don
By ’95, the 520-H had both and the -HC was, I believe, out of production
Mister_520H
9 hours ago, Handy Don said:
If your skills are up to it, you could remove that pin and replace it with a new piece of rod. Probably less work than my original suggestion!
WH tended to weld these types of things on only the “back” side of the bar so with care, you could get that piece off and put in a new one!
this sounds like another good fall project. I’m going to have to get my tractor back in operation ASAP as my grass waits for no man.
as for the drive belt replacement. Any thoughts on what appears to be an oem vs heavy duty aramid belt?
It looks like the new lift arm parts will be here today. I’m planning to pick up a clevis to fit the larger diameter hole snugly and then turn down the opposite end to match the ID of the smaller hole. Probably overkill but that’s my middle name.
peter lena
@Handy Don   more than agree with the lack of functional detailing on that lift arm set up , makes me think of an adaptive flange bearing set up , gorrect polyurea grease , personally think its way out out of its comfort zone , with loading , and activity . deck weight and rotational drag , field cutting  etc . would be towing a self powered , flail mower , guy up the road from me recently was field cutting , that rear  flail mower , made quick work of 4 ft field work ,  regularly  look over a problem spot for a cure , often a simple detail function issue , you can  also paint a change red , and hardly notice it , go greasy pete
Handy Don
I’ve had good luck (so far) with all of the D&D Aramid covered belts I’ve installed.
Others here strongly favor OEMs
The cover is the key--they resist wear longer and, on clutched tractors, give much smoother engagement
Ed Kennell
They work great for me on decks, blowers, hydro and gear drive trannys.   And when building customs,  I buy several lengths, use the one that fits best, and return the rest.
I always record the date and file the sleeve.
Lee1977
Posted (edited)
This is the belt I put on my 520-H about three years ago.
The 5/8" x 82" like Ed posted above I have on a couple of my 8 speeds.
Edited by Lee1977
Handy Don
Wow, you guys with dating and keeping belt sleeves are really impressing me!
Mister_520H
5/8 x 83 matches what I’ve found elsewhere. Aesthetically I’m not thrilled about putting a blue belt on this thing so I’ll just go OEM.
Handy Don
We each have our own priorities! :)
Lee1977
The last Wheel Horse belt I bought was made in Mexico. That's when I stopped buying belts from Toro.
Mister_520H
The new (used) lift assembly arrived this afternoon and a big storm blew in so I put my barn project on hold and switched back to tractor service. I’m re-cladding my workshop/barn and spent the day cutting battens until the weather took a turn.
Here are some side by side photos of my old lift and the new parts. Notable differences are the length of the hydraulic cylinder arm. I’ll definitely be using my original shaft. The rest of the parts are essentially identical with the exception of the shouldered clevis which I hadn’t noticed in the photos and solves my issue of mounting perfectly. Good news!
Mister_520H
Shouldered clevis sandwiched better the two arms. This design is confidence inspiring!
  • Excellent 2
Handy Don
Posted (edited)
Now that we have THAT settled! :)
I can see how by not looking closely I assumed that the holes were equal-sized. And, with no head on the clevis on the outside, it avoids clearance problems.
You look set to get to work!
Edited by Handy Don
kpinnc
Posted (edited)
Can't see it under the PTO bell anyway. :thumbs:
Edited by kpinnc
Mister_520H
Went ahead and installed the new lift parts onto my old shaft assembly today. Very straight-forward install. For those who were concerned, I dressed the entire interior of the lift mechanism with anti-sieze where it mates with the shaft. After a light honing it slid on like butter. Went through my manual and verified the setup for my 60” deck and got that installed. Final trunnion adjustment to set the max deck height to stop short of maxing it out like I had it previous to keep unnecessary tension off the lift arm when in the lifted position.
While watching the lift actuate I was somewhat concerned to observe that my hydraulic lift shaft at least visually appears to be slightly bent toward the end where the clevis attaches to the arm of the lift shaft assembly. I find it unlikely that it’s designed that way intentionally and even though the lift functions normally, I’m curious what you guys think about this. How it could have happened and what effect it might have. Hard to photograph but I tried.
The hydraulic cylinder swivels so I’m wondering what could account for the force necessary to bend the shaft. With the deck in the lowered position the angle of both shaft and cylinder are neutral and in the extended listed position they are still neutral.
Handy Don
Posted (edited)
28 minutes ago, Mister_520H said:
anti-sieze where it mates with the shaft - Yay!
Final trunnion adjustment to set the max deck height to stop short of maxing it out Yay!
The hydraulic cylinder can exert about 700 lbs of extend force (yeah, a lot). Less on retract, of course.
I’ll bet that the PO's “mods” managed at some point to bring that force against an immovable object and the rod was the weakest point so it bent.
These are not high-precision, high pressure units, but In time, it’ll probably put some extra wear on the seal and you’ll see seepage. Bending it back is a fools errand and I, for one, wouldn’t try it.
Me? I’d run it and also get and keep a spare cylinder planning for the day when replacement is the easiest option.
Edited by Handy Don
kpinnc
The cylinder lifts on the pull stroke, so it was likely bent because someone used a solid link in an attempt to place down pressure on either a grader or plow blade.
Mister_520H
Handy,
 That sounds like a good approach. I saw a few on eBay so I’ll grab one and add it to my parts stash.
Kpinnc,
I can’t speak to the tractors’s early life but it only came to me with a 60” deck and a snow thrower. I assume the thrower was used regularly as the PO saw fit to buy a cab to keep warm in the winter. Could the snow thrower have cause the damage? It’s possible that other implements were used in the past as well. I’ve only been the owner for about 7 years now and she lived a long life prior to that.
Below.. a few photos after the lift arm install. Ready for action!
Is it just me, or is re-installing the seat a real PITA? No part of tearing the tractor down for this job or putting it back together was difficult but getting that dang seat back on is a real nuisance. If it weren’t for the springs..
Also, I spent a good 10 minutes searching my shop for two footrest brackets and bolts assuming each side should have three but only having a total of 4 in my magnetic tray where all the hardware was organized. I finally examined the footrest and it was clear that though a square carriage style hole was present on the rear inner side, the rear surface showed no evidence of one being there on either side. Can anyone confirm?
Handy Don
As noted with the arm it connects too, there have been a few versions of that cylinder--both throw and overall length. With no urgency, and if you are coming to the Big Show, bring detailed measurements (both open and closed length to clevises, end pin diameters, overall diameter, hose connection positions) of yours with you and look for one there.
Can anyone confirm?
I do vaguely remember thinking there was an unused hole, but I may well have thought someone earlier has simply left it out added the “missing” bolts from my stash! 😄
Mister_520H
Handy,
 What is this “big show” you speak of and where is it held? That sounds like a good idea.
Handy Don
Posted (edited)
Not a Red Square event but a lot us participate.
Run by the Wheel Horse Collectors Club the Thursday-Sunday after Fathers’ Day, June 20-23.
It's at the South Mountain Fairgrounds in Biglerville, PA.
If you do a search here on this site you’ll find lots of posts--including this thread
Lots of vendors and folks just socializing
The club never updated their website with this year’s info but except for the date, this is it.
https://wheelhorseclub.com
Wheel horse stuff only! Leave your green, white, orange and other tractors at home,
I plan to be there and will be bringing a tractor to cruise around on.
Edited by Handy Don
lynnmor
Many don't use the heavy lift assist spring and depend on the cylinder to do all of the work, use that spring and check that it lifts a bit in all of the travel.  My thought is that traveling over bumps would put excessive forces as the snowblower bounces.
I have little issue installing the seat, I keep the springs bolted to the assembly and the seat tilted forward so it rests on the steering wheel.  It is a good idea to cover the painted surfaces to prevent damage.
Mister_520H
Run by the Wheel Horse Collectors Club the Thursday-Saturday after Fathers’ Day, June 25-27.
Ah okay. Looks like it’s south of Harrisburg. Gorgeous country. I’m about 4 hours west in western PA farm country about an hour plus north of Pittsburgh. I’d like to make it down. Would be fun to get my grandpa’s old wheel horse running and haul that down in the pick up. It’s a 50’s model I believe.
Mister_520H
Hmm. Perhaps flipping the seat forward as you said would help. Do you leave the forward brackets installed or remove them with the seat bracket? I always leave the springs mounted.
