WHX?? 48,813 #26 Posted May 22 Calibrated. I'll pump oil out of the pail into this. 2 quarts for a big block you say Bob? Seems like alot. What's a small block take? 2 Share this post Link to post Share on other sites
wallfish 16,994 #27 Posted May 22 1 minute ago, WHX?? said: Calibrated. I calibrated by mixing 40% Belvedere into the 60% full juice bottle, shake vigorously and pour over ice. Everything equaled out smoothly except my equilibrium. 6 Share this post Link to post Share on other sites
Ed Kennell 38,113 #28 Posted May 22 On 5/20/2024 at 2:36 PM, elcamino/wheelhorse said: every spring it was castor time, you have the memory Ed? I remember a bitter tea made from some kinda root and a procedure involving a water bag and a hose. 1 Share this post Link to post Share on other sites
Racinbob 11,048 #29 Posted May 22 (edited) 7 hours ago, WHX?? said: Calibrated. I'll pump oil out of the pail into this. 2 quarts for a big block you say Bob? Seems like alot. What's a small block take? Yup, 2 quarts but 1.5 if it has the oil pan for a wobble mount. 40 ounce for a 7-8hp. That is Wheel Horse spec blocks. There might be others out there. Edited May 22 by Racinbob 2 Share this post Link to post Share on other sites
WHX?? 48,813 #30 Posted May 22 3 hours ago, Racinbob said: wobble mount ... I'll be sure to check the dip stick. 11 hours ago, wallfish said: shake vigorously and pour over ice. Everything equaled out smoothly except my equilibrium. Nuttin like being well lubed. I'll have to have @Achto empty a 1.75 and recalibrate... 5 Share this post Link to post Share on other sites
Achto 27,562 #31 Posted May 22 12 minutes ago, WHX?? said: I'll have to have @Achto empty a 1.75 and recalibrate. This will also require one 20oz bottle Coke please. 3 Share this post Link to post Share on other sites
Racinbob 11,048 #32 Posted May 22 2 hours ago, Achto said: This will also require one 20oz bottle Coke please. You'll have to settle for a 591ml of Pepsi. 3 Share this post Link to post Share on other sites
