953 nut 55,229 #26 Posted June 7 Looking at other system wiring diagrams for your tractor I see that there is only ONE PTO switch, seems the Kill Relay performs the function the second half of the PTO switch on pre 1997 Wheel Horses did. Sorry about that. 4 hours ago, rwmastel said: If I connect to 1 pink and 2 grey, moving the lever should alter continuity. If I connect to 1 pink and 3 white, moving the lever should alter continuity. if I connect to 2 grey and 3 white, moving the lever should do nothing You are correct. If you apply 12 volts to the Gray wire of the PTO Switch wiring shown in your photo and then turn the key to START it should cause the solenoid to closer. If not recheck the Ten Amp fuses (I'm not sure which one). Share this post Link to post Share on other sites
rwmastel 47 #27 Posted June 7 14 minutes ago, 953 nut said: Looking at other system wiring diagrams for your tractor I see that there is only ONE PTO switch, seems the Kill Relay performs the function the second half of the PTO switch on pre 1997 Wheel Horses did. Sorry about that. You are correct. If you apply 12 volts to the Gray wire of the PTO Switch wiring shown in your photo and then turn the key to START it should cause the solenoid to closer. If not recheck the Ten Amp fuses (I'm not sure which one). I'll test that. Wife told me gray is in the center and pink on the right of connector! Share this post Link to post Share on other sites
953 nut 55,229 #28 Posted June 7 11 hours ago, rwmastel said: Wife told me gray is in the center That is correct, forgot you said you are colorblind. Share this post Link to post Share on other sites
rwmastel 47 #29 Posted June 8 Found a Toro dealer with a PTO safety switch in stock, swapped it out, and mowed the lawn tonight. BIG WIN! Thanks to everyone, specially @953 nut, you really provided me a good introduction to basic electrical troubleshooting. I really needed it! Your time and diligence is very much appreciated. I'll also be buying a starting solenoid. I noticed when reattaching my + battery cable, there is a Crack in the solenoid plastic. The journey never ends. Adios, amigos! 1 1 Share this post Link to post Share on other sites
