SylvanLakeWH 26,123 #451 Posted 17 hours ago Interesting that the rubber latches are mounted inside the hood on the Workhorse, but outside the hood on my C-105... I like yours better. Cleaner and less "in the way"... 2 Share this post Link to post Share on other sites
Ed Kennell 39,113 #452 Posted 17 hours ago 12 minutes ago, SylvanLakeWH said: Interesting that the rubber latches are mounted inside the hood on the Workhorse, but outside the hood on my C-105... I like yours better. Cleaner and less "in the way"... My 310, 312, and 520 are all inside. You do have to hold them out as you close the hood. 3 1 Share this post Link to post Share on other sites
Wayne0 549 #453 Posted 16 hours ago Literally a work of art!! 1 Share this post Link to post Share on other sites
cleat 6,668 #454 Posted 15 hours ago 2 hours ago, Ed Kennell said: My 310, 312, and 520 are all inside. You do have to hold them out as you close the hood. Yes, especially the 520. The rubber latch seems to want to default to the inside if you don't hold it. However, they do give you something to hold onto to pull the hood down. 3 Share this post Link to post Share on other sites
MainelyWheelhorse 627 #455 Posted 14 hours ago As I’ve said before, excellent work @cleatThe bar for a factoryesque restoration has been set. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 627 #456 Posted 13 hours ago 3 hours ago, SylvanLakeWH said: Interesting that the rubber latches are mounted inside the hood on the Workhorse, but outside the hood on my C-105... I like yours better. Cleaner and less "in the way"... 3 hours ago, Ed Kennell said: My 310, 312, and 520 are all inside. You do have to hold them out as you close the hood. My 92 312 and 87 308 are also rubber latches on the inside of the hood like @cleat’s Workhorse. 2 Share this post Link to post Share on other sites
Bill D 2,008 #457 Posted 13 hours ago The 300/400 series use the same hood. On my machines I take a piece of old seat edge trim and install it on the upper dash so it cushions the hood when it closes. 2 Share this post Link to post Share on other sites
MainelyWheelhorse 627 #458 Posted 13 hours ago 24 minutes ago, Bill D said: The 300/400 series use the same hood. On my machines I take a piece of old seat edge trim and install it on the upper dash so it cushions the hood when it closes. I used a piece of old but still good weather stripping on both of mine. It seems to work pretty well. 1 Share this post Link to post Share on other sites
cleat 6,668 #459 Posted 12 hours ago 1 hour ago, Bill D said: The 300/400 series use the same hood. On my machines I take a piece of old seat edge trim and install it on the upper dash so it cushions the hood when it closes. I normally do something like that as well. With this one I went a different route and glued a piece of rubber gasket material to the bottom of the hood. 3 Share this post Link to post Share on other sites
