cleat
Work Horse GT1600 restoration and conversion to Hydro
cleat
Left side cover ready to install.
Speed nuts clipped onto left side cover.
Rubber plug in side cover hole.
This cover is from a 520 with the parking brake in the side cover.
Tape lines laid out then the opei decal applied.
1715306192_Leftsidecovertapeontoguideopeidecal.JPG.338aa5b3f2bf7226d795bc0a1891621f.JPG
188085834_Leftsidecovertapeonopeidecalapplied.JPG.3400336c7b8b6351d7e67aba52d9916f.JPG
Speed nut clipped onto left foot rest.
Left side cover installed with just the front bolt and bottom screw loose.
  • Like 5
cleat
Right side cover ready to install.
Speed nuts clipped onto right side cover and right foot rest.
Carriage bolt and push nut installed into belt guard bracket that is up by the engine.
1120030838_Carriageboltandpushnutinstalledintobeltguardbracket.JPG.42cf8773c41bab0883d7143e46de7c44.JPG
Right side cover installed with just the bracket nut and foot rest screw loose.
1004110507_Rightsidecoverinstalledwithjustthebracketnutandfootrestscrewloose.JPG.9c193d8173bbf6f0da97d430f9c9f536.JPG
  • Like 5
cleat
Posted (edited)
Shift cover plate ready to install.
You will notice a small indent, this is for hydraulic valve handle clearance as it would contact the plate when pulled fully back.
Shift cover plate installed.
Left side cover fully installed and tightened.
Right side cover fully installed and tightened.
Tractor overview as of today.
Edited by cleat
  • Like 5
  • Excellent 3
cleat
When I ordered the decals from Terry, I asked him not to send the big TRANSAXLE decal that goes under the seat.
Therefor my tractor looks like this.
And not like this.
Nothing wrong with that decal, I just decided not to use it.
cleat
OK guys, I need your help.
I had Terry make me up a custom ID tag for this machine and he sent two with different fonts.
Which one should I use ?
Ed Kennell
I vote for the solid type.
  • Like 4
cleat
Hand push only decal installed.
Air cleaner maintenance decal installed.
1096759842_Aircleanermaintenancedecalinstalled2.JPG.2852fae3a8bf4fd6f30fe125606bf9ab.JPG
156858219_Aircleanermaintenancedecalinstalled1.JPG.bd60b67b2602ff6afe144e001d08a5ae.JPG
  • Like 5
ebinmaine
Me too. Definitely easier to read.
SylvanLakeWH
Me 3...
Bar Nuthin
On 1/4/2025 at 6:05 PM, Bar Nuthin said:
I feel like we're getting closer to decals every day! :banana-dance:
Johnny Carson as Carnac the Magnificent Tv Themes, Johnny Carson ...
  • Haha 1
cleat
Soon, maybe tomorrow.
cleat
This may help as well.
The solid is definitely easier to read but is one actually correct ?
ebinmaine
@JCM @MainelyWheelhorse. you got 80s rigs. Thoughts?
JCM
I think my original tractors have the non solid. I would have to check to be sure.
Bill D
On the gray GT series that decal goes on the hood stand near the PTO lever, not the fender.
cleat
Yes, mine was there as well.
Totally blank but there.
I like it better on the fender though so that is where mine will go.
kpinnc
Absolutely gorgeous! :thumbs:
cleat
Getting ready to apply the decals.
Terry made this custom decal kit for me.
First, the painted surfaces are thoroughly cleaned and de-greased for best adhesion.
The painted surface and back of decal is sprayed with this mixture of distilled water with a couple drops of dish soap so decal can be moved around before final placement.
1390290764_Distilledwaterwithafewdropsofdishsoapinspraybottle.JPG.0fef7a89bb250beb5441f8eaff9722a2.JPG
Once I am happy with the decals placement and absence of bubbles and wrinkles then I squeegee the water out using this piece of teflon wrapped in a heavy duty paper towel.
cleat
Posted (edited)
Center of rear fender marked on a piece of masking tape.
Center of rear decal also marked with masking tape.
Rear fender cleaned and sprayed with water mixture then decal applied lining up centerline marks
Decal squeegeed and fully applied.
Before VS after picture.
Edited by cleat
  • Excellent 5
cleat
Right side of hood ready for decal.
Right side hood decal ready to apply.
Right side hood decal applied.
  • Excellent 3
cleat
Left side hood decal applied.
cleat
Front hood decal applied.
  • Excellent 3
cleat
Caution decal applied to rear side of hood.
Overview as of today.
  • Excellent 3
cleat
One more vote for all you Work or Wheel Horse experts.
Should I use the period correct "TWIN' decal or slightly newer "HYDRO" decal.
Keeping in mind the hood decal already says HYDRO.
cleat
This is the ID tag on my 1988 312-8
Now I really don't know which one to use.
