cleat
Work Horse GT1600 restoration and conversion to Hydro
cleat
Dipstick and tube ready to install.
Dipstick tube installed.
Dipstick installed.
cleat
Hydraulic lift assembly ready to install.
939711001_Hydraulicliftassemblyreadytoinstall1.JPG.f1a16ea92ecabf95e07116e58b8b0fa7.JPG
859690203_Hydraulicliftassemblyreadytoinstall2.JPG.184d8ac4daca817d92e286c419b27330.JPG
Lift arm greased at bushing and never seized at bellcrank mounting area.
802975542_Liftarmgreasedatbushingandneverseizedatbellcrankmountingarea1.JPG.0c0d25b7518fa58629d6cacf8338ff1c.JPG
Right side lift arm bushing installed.
1157067325_Rightsideliftarmbushinginstalled1.JPG.cbce2ea7f011195db3ab47e03a2b1bc5.JPG
Hydraulic lift assembly installed.
Hydraulic lift cylinder installed.
  • Excellent 2
cleat
Overall view as of today.
I can't get too far ahead of myself or I will be done way too fast.
  • Excellent 4
cleat
Brake cam plate and rod assembly ready to install.
1381023318_Brakecamplateandrodassemblyreadytoinstall1.JPG.221a7b8f5c2fd2b34462d34816a0aede.JPG
1483683315_Brakecamplateandrodassemblyreadytoinstall2.JPG.167da7d65665e5312178739e3f5289de.JPG
Brake cam plate installed.
Brake rod installed.
  • Like 4
cleat
Brake pivot ready to install.
You will notice a yellow shim spacer on the bushing.
I punched that out of plastic shim stock to take all slop out of the pivot but still allow it to rotate freely.
A grade 5 bolt was used instead of stainless steel because I figured strength was more important than looks for this.
Brake pivot installed.
  • Like 4
cleat
Brake drum ready to install.
Brake shaft coated with never seize.
Brake drum retaining bolt with blue loctite applied.
Note the parts manual says to use 1" bolt but I installed a 1-1/4" since there was plenty of depth available in the shaft for it.
755361147_Brakedrumretainingboltwithblueloctite.JPG.e51dba8b900aebbd543a34a938d3c3af.JPG
Brake drum installed.
Edited by cleat
cleat
Brake band ready to install.
Brake band installed.
I used double stacked washers to eliminate excess plat between the brake band and cotter pin.
cleat
Brake spring assembly ready to install (sorry it's blurry).
1980407607_Brakespringassemblyreadytoinstall.JPG.78150d9de941f27c9cf18d2917d509e5.JPG
Brake spring assembly installed.
cleat
Brake pedal ready to install.
Brake pedal bushings installed.
Brake pedal installed.
1485063397_Brakepedalinstalled1.JPG.29252e1c7d6b6cca2f6627026a3c4669.JPG125352432_Brakepedalinstalled2.JPG.f7d0763b387b05c73c1e7a461140c063.JPG
Overview of entire brake system.
  • Like 4
cleat
Brake return spring ready to install.
Brake return spring installed.
ebinmaine
Do you ream that pedal or is it sized from the factory?
cleat
This pedal is from a 520H which comes with bushing from the factory.
The factory bushings are very short but these 0.5" long ones fit without issue.
Brake.pdf
cleat
Heavy duty lift bar assembly ready to install.
I made this pin from a piece of rod drilled for a hairpin clip.
2044421637_Heavydutyliftbarassemblyreadytoinstall1.JPG.f557416c917936881b8248d810c46ba4.JPG
Lift bar pin dimensions.
Wheel horse heavy duty lift bar pin dimensions.pdf
Heavy duty lift bar pin ready to install.
Lift bar installed.
Pin was greased prior to installation.
cleat
Hose and wiring grommets ready to install.
784217577_Hoseandwiringgrommetsreadytoinstall1.JPG.939f07b5d9f4575c003422fbd94743b5.JPG
Hose and wiring grommets installed.
cleat
Hydraulic valve assembly ready to install.
Valve and hoses all have new O rings installed.
Lockwashers shown were not used.
1988173945_Hydraulicvalveassemblyreadytoinstall2.JPG.97040528a14c8b5f3035a9f6f8ff10d8.JPG
Bracket bolted to hydraulic valve.
Hydraulic hoses hooked up between valve and cylinder.
249326762_Hydraulichoseshookedupbetweenvalveandcylinder1.JPG.33c068fc886465d44f0749aa9f57f8ca.JPG
717688851_Hydraulichoseshookedupbetweenvalveandcylinder3.JPG.77690567f4d5d5b04efa14a20da3e2c3.JPG
Edited by cleat
kpinnc
I really dislike that style of spool valve. They are prone to keeping a little air in them and can have quite a squeal until the bubble gets worked out.
My 523 uses that valve and it still squeals a little. Not as bad as when I first hooked it up, but it’s still there.
