cleat
Work Horse GT1600 restoration and conversion to Hydro
cleat
Believe me, it is making me fidget as well but I know that I will need something to keep me entertained during the winter so I will wait.
I could likely assemble the entire thing in a day or two but I will try and make it last as long as possible.
Taking lots of pictures and posting them to Redsquare also takes time and keeps me occupied.
  • Thanks 3
ebinmaine
And we appreciate you doing that!
kpinnc
Does wonders for the rest of us as well. Keep those pics coming!
953 nut
You are providing a valuable resource for anyone who wants to do the job right. This thread and the detail you have included is wonderful.    :text-thankyouyellow:
  • Like 7
kpinnc
:text-yeahthat:
Ed Kennell
2 hours ago, 953 nut said:
And entertainment for all that enjoy watching an artist at work.     We like pictures....:text-thankyouyellow:
  • Like 4
cleat
Assembled the front Tach and hood pivot assembly
All parts laid out ready to assemble.
Installed the latch lock assembly.
Greased the latch pin then installed the front Tach latch
Installed the hood stop pin.
This is a different design that I came up with that uses a 1/4" rod inside 3/8 tubing with a cotter pin in the center to hold everything in place.
The factory design has the hood pivots hit the cotter pins when tilted open.
Installed the hood pivot brackets and pin assembly.
The pivot brackets were badly worn so nuts were welded on then drilled out to provide a nice tight hinge action.
1856369915_Hoodpivotrodandbracketsinstalled2.JPG.5437b50762ae093fb2254d0e6cc173b0.JPG
1654961648_Hoodpivotrodandbracketsinstalled3.JPG.f86c056eb198ea6ecca857f011e0c7df.JPG
Front Tach lock shaft grip installed.
Front Tach decal installed.
  • Excellent 4
kpinnc
I mean this the best possible way, and I am not pushing sunshine here: You could create a “proper restoration” thread with your restores. Your work is awesome!
the front hitch on my last resto worked fine and it got painted in one pass along with the frame. Yours will function “as new”, as it should be!
ebinmaine
Just excellent illustrations and instructions here.
cleat
Brake bracket ready to install.
189627773_Brakebracketandhardwarereadytoinstall.JPG.6f3b8064bf1d52c27f9f0dd5ffdf03a6.JPG
Brake bracket installed.
  • Excellent 3
cleat
Hydraulic fitting ready to be installed with new O ring.
Hydraulic fitting installed into rear end and lightly snugged.
1347561037_Hydraulicfittinginstalledintorearend.JPG.a61e01b86dcb7c7250b8ca4985414a57.JPG
  • Excellent 3
cleat
Motion control plate ready to install.
Motion control plate installed.
  • Excellent 3
cleat
Cam follower arm ready to install.
Cam follower arm installed.
  • Excellent 3
MainelyWheelhorse
@cleat Nice work, It makes me want to redo my 308 back to factory.
cleat
Motion cam ready to assemble along with foot control bearing.
Motion cam assembled and cam bearing greased.
Motion cam pivot rod made of stainless steel, 2 stainless steel cotter pins, and 2 hardened steel washers along with OEM mounting bolt.
Complete motion cam assembly showing how rod is installed.
  • Excellent 2
cleat
Mid Tach ready to install.
Mid Tach decals installed.
Mid Tach lock assembly ready to install.
Mid Tach installed.
Mid tach grip installed.
Overview of frame and Tach assembly.
  • Excellent 2
cleat
Lower steering shaft flanged bearing ready to install.
1207564399_Lowersteeringshaftflangedbearingreadytoinstall.JPG.1b1084df89989db8e992ddc6e85fb44a.JPG
Lower steering shaft flanged bearing installed.
52739887_Lowersteeringshaftflangedbearinginstalled1.JPG.85742be006af16eac0ab4598b8d6dc93.JPG
139555155_Lowersteeringshaftflangedbearinginstalled2.JPG.d9abf5f464df626554715055f81019d1.JPG
Frame overview showing mid Tach and Lower steering shaft flanged bearing.
1488637468_FrameoverviewshowingmidTachandLowersteeringshaftflangedbearing.JPG.d8e08ef1de0633da5656018716a71c9a.JPG
  • Excellent 5
SylvanLakeWH
Beautiful work!!! :handgestures-thumbupright:
ebinmaine
flanged bearing
Do you install other bearings around other shafts like the steering upper or whatever?
Extras that Wheelhorse wouldn't have had originally?
cleat
Yes, anywhere there is play in the steering I try and add a bearing or bushing to tighten it up.
For the 300 and 400 series the easiest fix is to install a flanged bearing normally used on the lower shaft to support the upper shaft.
For the early 500 series I use a front wheel bearing in the original bracket after drilling it out to 1-3/8" to fit the bearing.
1205712402_Upgradedsteeringshaftbearinginsweptaxle5201.jpg.1422075388d13543dd9736c3769983b9.jpg
For the later 500 series I drill out the dash to 1-3/8 where the original bushing would normally be and install a front wheel bearing.
1899748933_Upgradeduppersteeringshaftbearing3.jpg.426ae129be68e55c4285f63878a7c580.jpg
The steering support block gets drilled and new brass bushings installed top and bottom to get rid of any play.
Brake and clutch pedals just get new bushings as required.
  • Excellent 3
kpinnc
Bleeping awesome! Not only restored, but improved! :bow-blue:
ML3
@cleat as usual its enjoyable to see the progress. The attention to details is incredible. You remind me of an old boss of mine named Gary. His cars, motorcycles,  house, tools , everything he owned was & is always perfect.  He has a saying that he keeps everything nice for the next person that buys it. Lol! Anytime he decides to sell whatever it may be I usually buy it whether I need it or not. He makes everything better & improved.
Edited by ML3
