cleat
Work Horse GT1600 restoration and conversion to Hydro
ebinmaine
Niiiiice
cleat
Rear end wire brushed, sanded, primed, and painted high gloss black.
  • Excellent 5
ebinmaine
Interesting method of holding the transmission case off the ground.
Have to remember that...
cleat
Just a piece of 3/4" rod at the rear and a 3/8" bolt at the front with 3 jack stands.
I use the tractor loader to lift it up.
I will take pictures of the rigging when I put it back inside.
cleat
Rear end rigged for lifting.
588312171_Rearendrigging5.JPG.df784e91d1b3bf52368b1b9c06b51be3.JPG805487575_Rearendrigging6.JPG.10f2f23fb41055a193781d1a825f5437.JPG
  • Excellent 2
cleat
Rear end moved to the shop and sat on jackstands.
This is how it will rest until next winter.
c-series don
 @cleat What kind of paint did you use on the rear end?
cleat
I used Rustoleum spray bombs.
Grey primer and gloss black enamel.
cleat
Intake manifold and throttle linkage components bead blasted and painted.
662386139_Intakeandthrottlelinkagespaintedreadyforassembly.JPG.0853e7043fde9397450aa184bd95dd6a.JPG
Intake manifold and throttle linkage components assembled.
1175659777_Intakeandthrottlelinkagespaintedandassembled1.JPG.a95c5eb970c82485316b90b1b9e0844c.JPG
1411154647_Intakeandthrottlelinkagespaintedandassembled2.JPG.14a0311ad2d506c67f594c426ff5ddec.JPG
1449015563_Intakeandthrottlelinkagespaintedandassembled3.JPG.83f905b770598d5f7a048988a4a49f40.JPG
1804619841_Intakeandthrottlelinkagespaintedandassembled4.JPG.a1b5a41750ac621db6befded421c2883.JPG
Lee1977
Show it to Trina, you, won't remember it, you have it bolted back to the tractor before do.
ebinmaine
You are 100% correct. And I did show it to Trina. :lol:
cleat
My new muffler deflector with louvered outlet has arrived.
I got it for $3.50 CDN ($$2.19 US) so I am very happy with this.
  • Like 5
cleat
I still need to paint the muffler.
On the fence with black or silver.
Factory colour I believe is silver.
ebinmaine
I don't know the original color but the silver would contrast the black engine nicely.
cleat
Dash console bead blasted and welded up on the lower corners where it has some cracking.
Sanded welds smooth.
Rear of Hoodstand there front fender bracket bolts on there were some cracks.
These have been welded and ground flat.
Started sanding entire hoodstand until the rain started (I try and sand outside to keep shop as clean as possible).
  • Excellent 5
ebinmaine
Do you add any extra reinforcement here?
Extra washer. Piece of flat stock...
cleat
I will add some thick fender washers there during assembly.
cleat
Blower housing and static guard assembled.
714567020_Blowerhousingandstaticguardassembled1.JPG.d0a9676a8ecaeaac3da47ee02b9ef330.JPG
1284481768_Blowerhousingandstaticguardassembled2.JPG.3867cd83af5f5f055330543762e1f411.JPG
332677876_Blowerhousingandstaticguardassembled3.JPG.d0af95f20d4956c5777e5d51c3a83056.JPG
  • Excellent 2
cleat
Installed rubber plug into hole in static guard.
Guard came to me with this hole, I assume they used it to check RPM.
cleat
Genuine Briggs gasket set arrived so I installed and torqued heads and valve breathers.
Bolts were lubricated with copper anti-seize.
1050784242_Headsandbreathersinstalledandtorqued2.JPG.39c2275ca6833f89955e533f3fde09db.JPG
  • Like 4
WHX??
Just caught this resto :popcorn:... nice work as usual Cleat...:handgestures-thumbupright:
Handy Don
I’d suspect that it held a medallion.
Bill D
Is that a good idea on an aluminum block?  I always use the silver never seize on an aluminum parts?
cleat
Well, we will see (or hopefully the next owner) how it worked.
cleat
Console primed and painted.
Hood stand primed
Hood stand painted.
  • Like 4
