cleat
Work Horse GT1600 restoration and conversion to Hydro
c-series don
As others have said, this is not looking like a winter project! It’s looking more like summer project! Please slow down with all the progress, as it’s putting mounting pressure on me to get that crankshaft pulley to you 😂😂 When I saw that you painted even the little e-clips I thought to myself “man, this guy is as crazy as me!” Just can’t do it half ass, just can’t. Period.
  • Like 4
cleat
Yes, I am painting every little piece and bead blasting what I can.
That makes it take as long as possible and of course will make the final product better.
I am trying to straighten the engine air duct the best I can.
If you have one in good shape that would be awesome.
Don't worry, there is still a long way to go.
cleat
Flywheel painted.
Engine during cleaning.
Soaked with degreaser.
Engine cleaned up ready for more disassembly.
Starter as removed after engine cleaning.
Edited by cleat
  • Excellent 2
cleat
Pulled head back off after engine degreasing.
Pulled exhaust valve.
Pulled intake valve.
Both valves now pulled.
Lapped intake valve and set valve clearance.
This is the lapping compound and valve spring compressor used.
Piston and block cleaned.
Valves both installed
New intake valve seal installed.
Edited by cleat
  • Excellent 2
kpinnc
As usual- beautiful work! :thumbs:
Bill D
Nice work.  Are you going to open up the engine and check for wear on the pin holding the crank gear to the crank shaft?  I saw a video on YouTube where the gear was moving on the crank shaft due to the crank pin being worn almost in half.
cleat
I'm not sure.
Likely the OCD will kick in and I will.
End play is at the high end as well so I could fix that at the same time.
cleat
Starter painted.
I did not open it up as it was working fine.
Bill D
51 minutes ago, cleat said:
Starter painted.
FYI, there are NOS 18 HP Briggs opposed twins for sale on eBay right now.  Two different models from the same seller.  About $43 difference between the two.
The same seller (small engines for less) has new 22x7.50-12 wheel and tire combos for sale.  They look to be on Wheel Horse rims.
cleat
Thanks for the info.
I won't spend that much right now unless my engine fails.
Hopefully it doesn't.
cleat
Air guide frame painted
Engine block painted.
Valve covers cleaned out using brake cleaner until screens looked clean and discs moved freely.
Fly might be getting high from the fumes.
Easton Rich
Fly don’t know what’s happening to him but he likes it:P
  • Haha 2
cleat
Masking removed from engine.
All bolt holes tapped out.
Head bolts, valve cover bolts, and alternator bolts cleaned up and painted.
184945583_Engineandboltspaintedandallholestapped1.JPG.9ab9fbf26f64f91735a7cce81fd4e186.JPG
1433852380_Engineandboltspaintedandallholestapped3.JPG.9d1658cd4829bbd63cdc03296be4c38c.JPG
1974988084_Engineandboltspaintedandallholestapped4.JPG.0338caab0a79133e8b10e9b4d122248a.JPG
Heads degreased and washed.
  • Like 4
cleat
Valve covers painted.
cleat
Decided to try soda blasting the heads clean.
This is the home made soda blaster built from a blow gun and a piece of hose.
I just used old expired baking soda.
Pressure used. Around 50 PSI
Soda blast work area.
One head complete.
Both heads complete.
It took both boxes that were around 3/4 full each.
Wire brushed the inside of the heads.
  • Excellent 4
cleat
Heads sanded flat.
Cyl #1 head was fairly flat and did not rock around on block.
Cyl #2 head rocked on the block and took a lot of sanding to sit flat and also to get an even finish when sanding.
Sits and looks good now.
cleat
Heads loosely installed onto block as I don't have gaskets yet.
  • Excellent 3
cleat
Starter installed and torqued.
Valve covers loosely installed with no gaskets.
744547527_Valvecoverslooselyinstallednogaskets.JPG.db0b81ff7a558c717796b75e23125158.JPG
  • Like 4
cleat
Frame wire brushed and sanded.
Frame primed.
  • Like 4
  • Excellent 2
cleat
Frame painted.
  • Like 5
  • Excellent 3
ebinmaine
Is that as ridiculously simple as it looks?
cleat
Yes, it worked well for a couple of small parts.
Just had to keep wiggling the black hose around in the baking soda to keep it flowing.
Edited by cleat
cleat
Blower housing and static guard as removed.
643938281_Blowerhousingandstaticguardasremoved1.JPG.de250cadfa446ce0205fede3590814f1.JPG
1255836486_Blowerhousingandstaticguardasremoved3.JPG.0e30416a3bd34bd424a186ed56f362f6.JPG
Blower housing and static guard washed.
1628998876_Blowerhousingandstaticguardwashed1.JPG.713b59114b96d5823c3b815d5e83b89d.JPG
1287873999_Blowerhousingandstaticguardwashed2.JPG.0b5fb72ce34ac88d6e06bec821b0acf0.JPG
431623655_Blowerhousingandstaticguardwashed3.JPG.c72d064e1a80145173f7b9b5d5ed56ce.JPG
cleat
Blower housing and static guard bead blasted, primed and painted.
It is currently 30 with a heat index of 40 degrees C (86 with a heat index of 104 degrees F) and we are not used to that here so it makes work a little harder.
Good thing is the paint dries quick.
946568101_Blowerhousingandstaticguardprimed1.JPG.12b1446219f671b02f743292c964cbe8.JPG
393929945_Blowerhousingandstaticguardprimed5.JPG.b63e3fcc2cfd96bf2782a88fd67658a7.JPG
1825933381_Blowerhousingandstaticguardprimed6.JPG.45bb4405aee33de5dd2c3f040dc24ab2.JPG
cleat
Blower housing and static guard painted semi-gloss black.
Not the best pictures, I will get better ones when the paint dries more.
1684208633_Blowerhousingandstaticguardpainted1.JPG.0cc5a64333eb818993b8006a898ded8f.JPG+
577741697_Blowerhousingandstaticguardpainted5.JPG.76074780110d685b2851cd8e7ce4b35f.JPG
1849217652_Blowerhousingandstaticguardpainted3.JPG.fea25e3ca0e7efcaa51b242469c049fb.JPG
  • Excellent 2
