Keaton
two more round hoods (rj 59 and 702)
Keaton
i picked up my rj 59 and 702 this morning, nice guy got them loaded right up and he gave me a set of transmission seals and a couple manuals and brochures. i got them home, and hoped the rj ran, he said it did, it started right up. ran gread, took it down the driveway and back and started leaking engine oil through the pan, but besides that was great. it deffinetly needs a tranny rebuild, in one of packrats videos on youtube it says what the problem is, i forget right now but will give updated, the 702 is not bad, i just put it in the shead for now and am going to leave it for a bit untill i get my lawn ranger back togher and 856. i will post updates and the rj tranny case was a early one it was
D-8-59 witch if im right is april 8th 1959, and did anyone know the early rj-58 had a leather shifter boot?
  • Like 4
oliver2-44
Yes’ Thats very collectible if it’s still in one piece.   Others on here might have suggestions on how to preserve it. I’m thinking clean with a soft brush. Maybe some carefully with some saddle soap. Then soak with Needs boot oil.
Keaton
@oliver2-44 oh, i dont have one but that guy that sold me my rj had a rj 58 with it
Racinbob
:wwp: @Keaton
What's going on with the transmission? I'm guessing it's not staying in 3rd gear. :)
Pullstart
:text-yeahthat::banana-gotpics:
OoPEZoO
Does anyone have a pattern for an original RJ leather shift boot?  I have some contacts locally that I’m pretty sure I could talk into making some reproductions. I imagine they are relatively simple, but I’ve never had my hands on one personally.
Pullstart
@wallfish don’t you have an RJ with one?
wallfish
Made it myself out of an old leather  work boot for the early RJ-58.
rjg854
Any chance you can take a picture of it?
Probably most of us have never seen one.
wallfish
I sewed a small loop at the base with a wire in it.
Very early RJ-58 with the more crude rear hitch and the round axle hubs. No cast date on the trans
Keaton
sorry i got some, it runs great besided the transmission, and could. and @Racinbob it goes in 3rd fine. and i also scored a red devil load hog dump cart for $25 before i went and got thoes two, and also i got this shead all cleaned up and got 3 tracors instead of 1 in there and a bunch of other stuff
  • Excellent 2
Keaton
and how does  the throttle cabel go on a rj 59, i am not shure how it goes, someone got a picture or something??
Racinbob
From what we can see the throttle is correct, at least above the hood. It goes into 3rd but does it stay there when you are driving it? What's it doing to make you think it needs rebuilt?:)
Keaton
it stays in 3rd but if i push it backwards it clicks, look at this video https://www.youtube.com/watch?v=OJ7YTcJwmCs&t=40s
and how does the throttle hookup down to the engine, i have a new cable. does it go on the head bolt or how is it routed
Keaton
later this summer i will patina restore it, and i figured out how to hookup the throttle. the engine is also a  really nice blue green color, it runs a good low quiet idle.but nothing elese for now
Keaton
never mind i need help on how to route this throttle cable. i got pictures of it, i watched packrats video on his 401 but it was not the same on the k91 i got pics of it and i love the color of that block
Edited by Keaton
  • Similar Content
    • Rugerhound
      By Rugerhound
      Greetings everyone!
      I'm a new member to this forum and a new Wheel Horse A-100 owner.  I'd been looking for an inexpensive fixer-upper riding lawnmower to make my yardwork a little easier for an aging fellow like myself.   Snagged this A-100 for $250 that's in really decent shape for the most part.  The mower deck has some problems however, but the actual tractor is in great shape.  Doesn't look as though it was used much, and still has all the original tags on the Briggs  & Stratton stickers on the housings.  Engine sounds fine but the needle isn't shutting the fuel off properly, so it runs rough until it's revved up a bit.   The pedals have scarcely any paint worn from them.   Quite remarkable for a '77!
      So I have one of the blade shafts bound up, another that doesn't feel all that nifty.  I don't know if those bearings are sealed, or whether anyone might be able to clean 'em up and repack them for continued use.  Pulleys are in rough shape but I may be able to salvage them.    Any info on the bearings in the mower deck would be very helpful!   (Including recommended grease type, etc.)
      Also it needs a key... The Ignition switch is an INDAK 103991 which appears to cross to a Toro.   New switches are available, but does anyone know if it's possible to just purchase a replacement key?
      I'm guessing it takes typical non-detergent 30W oil...  It's a '77 model Briggs & Stratton 10 HP.  (Model 251707, code 77040412)  What fluid does the gearbox take?
      Thanks!!
      Regards,  Pete (Aka Rugerhound)
    • rwmastel
      By rwmastel
      Hi.  I just bought (but haven't brought to my house yet) a 1999 314-8 with a 48" side discharge mower deck and 650 hours on it.  I've been to the files section and downloaded lots of manuals. This is a great site and helped educate me the last few days when making my purchasing decision.  I look forward to contributing throughout my ownership!
      Rodd
