Doodad
WASHING PROVED DEADLY
Doodad
Posted (edited)
Well, I guess I've gone too far this time. I've got what I believe to be a 1974 Wheel Horse C-120 (12 HP Kohler serial7326629) that has performed nicely so far but looked a bit dirty so I had the great idea of cleanin' her up a little. Washed the tractor but the engine was dirty and I thought it would be nice to clean that up too so I sprayed some orange citrus cleaner on it and hosed it off and boy it cleaned right up and looks great...the only problem is, now it won't start...just grinds when I key the switch. I'm getting ready to take the hood off and check for spark but I'm suspicioning it's probably sucked water into the carb when I tried to pull it into the shop after washing. Anyway, that's my starting point but, before I go to far, I wanted to see what the Wizards of Wrenches have to say about what's wrong. I did get it to backfire and consider that an improvement but, no-starty, me no smarty. From the Doodad
Edited by Doodad
added engine serial number
  • Sad 1
87 416-8 horse
Does the engine spin over at all?
Doodad
Oh yes...the battery must be a Sears Die Hard because I've ground it for 10 minutes and it grinds fine, just won't start.
87 416-8 horse
If you have a spark tester then test the spark. If you don’t have spark then take an air blower and use it to help dry the coil out.
87 416-8 horse
By the way.
 :text-welcomeconfetti:to:rs:
Doodad
Okay, should I take the spark plug cap off the coil? I was going to remove the spark plug and lay it on the side of the engine to test the spark. That will work won't it?
Doodad
And, by the way, thanks for the welcome...I needed that right now.
From the Doodad
87 416-8 horse
Posted (edited)
Yes. You don’t need to use a lot of pressure. Just a nice flow of air all around the coil to dry it out.
Yes, that should work!
Edited by 87 416-8 horse
Doodad
Okay, I'm heading out to the shop to try that. I'll get back to this in a few minutes. From the Doodad
Doodad
Nope, no work for this jerk...I took the spark plug cap off the coil and turned a leaf blower down onto it and left it for a few minutes and then tried it and it just cranked and with choke closed, smells like flooded. The spark plug did spark but not very well so I'm going to head to town to pick up a new spark plug. If you've got any other suggestions, I'm open. One thing, when I took the breather cover off and removed the air filter, the outer foam filter was wet but the inside of the paper filter didn't seem wet...still, I think it might have sucked water into the carb but, overnight (all this happened last night) it should have dried out. I hate like the dickens to take the carb off because I'm not in any way a good carb man but all it can be is either spark, fuel, or air and if its getting spark to the piston (which it seems to be) then that means either fuel or air and there's plenty of air with the breather cover off so doesn't it have to be fuel? From the Doodad
Doodad
Timing...I left out timing, but washing the engine shouldn't have hurt timing. From the Doodad
squonk
You got water in the points. Take off the points cover and dry them out. Same thing happened to me.
87 416-8 horse
Washing it shouldn’t affect timing. A fresh spark plug could make a difference. I’ve had them fail before. Also check the points like @squonk said.
Pullstart
Grinding, like bad sounds?  Or cranking, like the engine spins but won’t start?
Doodad
Just got back from town with new plug. I wondered about the points. I'll take off the points shroud and dry them out, put in the new plug and hope the battery holds out. No, not a bad noise grinding...just regular cranking. I'll let you know how this remedy does. From the Doodad
Doodad
It was the points. Dried 'em out and ran a 220 grit sandpaper between them and it started right up. BIG THANKS TO ALL from the Doodad!
  • Like 4
  • Excellent 3
pfrederi
Posted (edited)
That is why my horses rarely get wet!!!  Excessive dust rarely causes issues.  I blow mine off with compressed air sometimes...  Dry the points and the spark plug wire
Edited by pfrederi
oliver2-44
953 nut
:WRS:
Glad you got it running.   One other component that is susceptible to water intrusion is the condenser, it should be mounter with the wire pointing downward.
moe1965
Take the points cover back off and put a index card or paper between the points and close them with the paper between the two points and gently pull the paper. It will clean and crud between them.   Just a follow up after you ran the sandpaper through.  Glad to hear your up and running.
lynnmor
:text-yeahthat: Sandpaper can leave stones embedded in the points faces and prevent contact.   A fine points file is better, but if you use an abrasive, cleaning with a card is important.  Also, electrical contact cleaner is also a good thing.  If you have a rubbing block on the points, be sure to lubricate where it rides with the proper grease, a tube of this will last you several lifetimes:
Doodad
Thanks for all the comments. There for a while, I thought I was up the creek without a paddle but you fellows came through. I did this once before about 20 years ago with a tractor of a different color which I will not name in polite company and - at that time - just ditched it, but I was working back then and didn't have time to try to fix the problem. Now, retired, and almost 75 I've got the time but unfortunately don't have the body for it but this was something I could fix and did. I've been into tractors for some time now and have restored a few. Thanks again "podners," You've been a good help to an old man...made my day (but, anymore, a good bowel movement is something to celebrate). From the Doodad
  • Like 4
  • Haha 2
Pullstart
We are here to help, everything but bathroom duty we leave that up to @SylvanLakeWH :lol:
  • Haha 3
953 nut
I've got a few years on you, trust me when I tell you it doesn't get any better with age.  Enjoy what you have while you have it.
SylvanLakeWH
:scared-eek:
Ya know, my Dad always said "No job is finished until the paperwork is done "... :handgestures-thumbupright:
  • Haha 4
  • Similar Content
    • mhvt
      By mhvt
      I have an old B 82 (from the 60s) that will not start. Started earlier today. I have tried everything.
      Basically, it sparks but it does not turn over. What could be happening here?
    • TailGate18
      By TailGate18
      Need help please
      Can't exactly identify my wheelhorse. I believe I've pinned it between 74-79 but not sure exactly. I'm not real knowledged in mowers but interested in learning. It ran few years ago. Then parked in a storage unit for about 3 years with gas left in it. I can't get it to run at all unless using ether.
      I've drained all the old gas, I've replaced the fuel lines, new plug, new gas, but it just won't start up and keep going. I figured on new carb but don't know exactly what I'm looking for and thought I'd better know the exact details of the mower so I know I get the right parts. Any help would be appreciated. The info I do have is as follows.
      The mower itself all I could find was one tag on the frame under the gas tank.
      ID # 61-08K801-05782
      Then under that 4 digits
      6337
      Has a Kohler motor info as follows
      Model-K181
      Spec- 30538
      Displ (cc)- 305
      Serial #- 2613800539
      It'll crank but not start. Not even attempt to start. With the fuel line off of the fuel pump it shows it pumps fuel. I thought the possibility of the float being stuck in the bowl but again not very knowledged in this field. Would appreciate any insight, details, knowledge, help or anything of the sort. Or info on the information of the tractor so I know exactly what I'm asking questions about
      Says it's a B-80 8 speed
      Thanks in advance
    • Chuck14025
      By Chuck14025
      12.6 volts in the battery and at the starter connection.
      10 volts on the gauge.
      Nothing when key is turned on.
    • Jpud
      By Jpud
      I have I believe is a 73 commando 800 8hp kohler k181s put a new switch on it due to starter sticking on and got a new starter and completely charged the battery and new solenoid has power to the battery side of solenoid but not starter side but will turn over if jumped has no power going to the switch. Wondering if anyone had this problem before
    • lodestonefarm
      By lodestonefarm
      I went out to use my 520H with blower this evening and it won't start.  I used this machine a few days ago (for the first time this winter).  The battery has been on a trickle charge so I don't think that's the problem.  It's done this before where it won't start, won't start, and then starts.  Usually that is in cold weather and after I've previously used it to blow snow.  I don't have a heated garage so I think it might have some ice somewhere that was introduced as water the last time I blew snow.
      Here's what it's currently doing.  When I turn the Ignition to 'On' the red warning lights and the dashs light all come on.  When I turn the key to start position I get a single 'Click' and nothing more.  I tried jumping it from a hot battery just to rule out a bad battery.  Same behavior.  Following some of the other threads about 520s with trouble starting, I pulled the blue wire off the starter solenoid.  If I run a jumper wire from the (+) side of the battery directly to the solenoid I get the same behavior (regardless of key being in on or off position)- small spark where my jumper wire is touching the battery terminal and a single click.
      I'm unsure what this means about the solenoid and if that, in any way tests, the starter.  Could it be that my starter is bad/frozen?  I tried using a heat lamp to warm up that area, but in this weather (and my garage, which is really just a tarp shed) that just isn't going to work.
      I've downloaded the demystification guide and started looking at it but I'm hoping someone might have some suggestions.  Snow is falling and I'm not making much headway on this.
      Thanks
