siebenaler 114 #1 Posted May 9, 2024 I have one that is leaking bad is there a fix or find a different one? Share this post Link to post Share on other sites
ebinmaine 70,789 #2 Posted May 9, 2024 Likely it can be rebuilt using a parts kit from Wheelhorsepartsandmore 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,246 #3 Posted May 10, 2024 1 Share this post Link to post Share on other sites
Handy Don 13,340 #4 Posted May 10, 2024 (edited) 2 hours ago, ebinmaine said: Likely it can be rebuilt using a parts kit from Wheelhorsepartsandmore These are not complicated and run at modest pressures--the seals are all o-rings of various diameters and thicknesses. Only if the valve body itself or the sliding valve is scored will complete replacement be necessary. Note that on Eaton-equipped tractors, the control valve also has an internal pressure relief valve with its adjustor covered by an external acorn nut. Best to resist temptation and just leave this alone unless you have a known problem that calls for adjusting it and the equipment to properly test it. They are sensitive to adjust and if done "by guess and by gosh” can easily cause more problems. My experience showed me that very small turning of the screw moved the relief pressure a lot. Also, with the acorn nut off, oil WILL leak. Edited May 10, 2024 by Handy Don 1 Share this post Link to post Share on other sites
c-series don 9,445 #5 Posted May 10, 2024 The hardest part of rebuilding the valve is taking it out and putting it back in. The actual rebuild is very simple. 3 Share this post Link to post Share on other sites
siebenaler 114 #6 Posted May 10, 2024 21 hours ago, ebinmaine said: Likely it can be rebuilt using a parts kit from Wheelhorsepartsandmore Thanks just ordered it. 2 Share this post Link to post Share on other sites
