KW88 39 #1 Posted May 8, 2024 In need of pair of axles WH part # 102764 Share this post Link to post Share on other sites
953 nut 68,982 #2 Posted May 9, 2024 You can post this in the wanted section https://www.wheelhorseforum.com/classifieds/wanted/ or call Lincoln at A-Z Tractor parts https://www.a-ztractor.com/ Share this post Link to post Share on other sites
KW88 39 #3 Posted May 9, 2024 59 minutes ago, 953 nut said: You can post this in the wanted section https://www.wheelhorseforum.com/classifieds/wanted/ or call Lincoln at A-Z Tractor parts https://www.a-ztractor.com/ I tried A-Z... no luck 1 Share this post Link to post Share on other sites
JoeM 10,233 #4 Posted May 9, 2024 Toro 520xi and 522xi use the size axles with the only difference is the key way being straight and not woodruff key. Uses the same hub. Maybe you can find a pair of those xi axles used??? Toro XI part number 79-3340 1 Share this post Link to post Share on other sites
KW88 39 #5 Posted May 9, 2024 20 minutes ago, JoeM said: Toro 520xi and 522xi use the size axles with the only difference is the key way being straight and not woodruff key. Uses the same hub. Maybe you can find a pair of those xi axles used??? Toro XI part number 79-3340 Would you happen to know the part # for that key ? Share this post Link to post Share on other sites
JoeM 10,233 #6 Posted May 9, 2024 5 hours ago, KW88 said: Would you happen to know the part # for that key ? Standard Square Key stock, 1/4x1/4" 2 inches long, hardware store stuff. xi part number is 1 Share this post Link to post Share on other sites
