Mark siebenaler 88 #1 Posted May 8 Mine is leaking at the ram seal . Is this a hard fix and looking for the correct seal? 1 Share this post Link to post Share on other sites
lynnmor 7,310 #2 Posted May 8 3 minutes ago, Mark siebenaler said: Mine is leaking at the ram seal . Is this a hard fix and looking for the correct seal? I have complete seal kits for cylinders with the large snap ring in the end. 1 Share this post Link to post Share on other sites
daveoman1966 3,752 #3 Posted May 8 If your 'ram' is the older type with welded shut ends, you can try this: Did this to my 74 C-160 ram and it still does NOT leak. For all the other style rams, there are seal kits available... I think the RS Vendor 'Wheelhorsepartsnmore' also has kits... Look in the VENDOR'S section. 1 Share this post Link to post Share on other sites
953 nut 55,325 #4 Posted May 8 1 hour ago, Mark siebenaler said: Mine is leaking at the ram seal . Is this a hard fix and looking for the correct seal? Let us know what the model number of your is. Lowell has the kits for all of them. https://wheelhorsepartsandmore.com/product-category/hydraulics/page/3/ Share this post Link to post Share on other sites
Mark siebenaler 88 #5 Posted May 9 4 hours ago, daveoman1966 said: If your 'ram' is the older type with welded shut ends, you can try this: Did this to my 74 C-160 ram and it still does NOT leak. For all the other style rams, there are seal kits available... I think the RS Vendor 'Wheelhorsepartsnmore' also has kits... Look in the VENDOR'S section. That's Cool good job my c160 isn't leaking it's the Bronco Share this post Link to post Share on other sites
Mark siebenaler 88 #6 Posted May 9 It's a Bronco 14 it's not welded nut I've been meaning to get a hold of Lowell for other parts too. He isn't to far from me. Thanks mark Share this post Link to post Share on other sites
Mark siebenaler 88 #7 Posted May 9 4 minutes ago, Mark siebenaler said: That's Cool good job my c160 isn't leaking it's the Bronco Oh I think I'm off a bit I bet mine are like yours crap.. Share this post Link to post Share on other sites
Mark siebenaler 88 #8 Posted May 9 11 minutes ago, Mark siebenaler said: That's Cool good job my c160 isn't leaking it's the Bronco I will be doing your fix. I'm good at tapping 5/8 inch in Won't go to deep.? #4copper washer Hardware store? Champer one side for a slight angle? Share this post Link to post Share on other sites
daveoman1966 3,752 #9 Posted May 9 Yes...Champer (concave) slightly the INNER rim of the copper washer (plumbing supply store) ---that helps 'crimp' the rubber O-ring tightly around the shaft (3) to prevent leaks. Drill the 3 holes to est 5/8" deep. When all done, GENTLY tap the outer rim of the copper washer to contour neatly against the ram body. Share this post Link to post Share on other sites
pfrederi 17,741 #10 Posted May 9 Wheel horse parts and more will cut reseal and reweld your cylinder. Have gotten at least two from him... work great... 2 Share this post Link to post Share on other sites
