carlosking450 155 #1 Posted May 2 Hello everyone, a long time ago I bought a sticker for my Wheel Horse 702 for the frame where the clock and throttle and starter handles are located. The fact is that since it is a sticker it starts coming off. Do you know if anyone sells something similar that instead of a sticker is hard plate or something similar like the original, silkscreen printing on an aluminum plate would also work. Gracoas from Spain Share this post Link to post Share on other sites
Sparky-(Admin) 21,354 #2 Posted May 3 What’s on the decal? Shift pattern, or model/serial number? Share this post Link to post Share on other sites
rmaynard 15,550 #3 Posted May 3 This is the set from @Vinylguy redoyourhorse.com. If the base plate is properly prepared, the decal should not come off. Share this post Link to post Share on other sites
carlosking450 155 #4 Posted May 3 The sticker I bought for the painting was very thin, however the original is like a hard screen-printed plate, it does not come off but when you tighten the screws in the corners or the frame of the amp clock it turns and comes off Share this post Link to post Share on other sites
rmaynard 15,550 #5 Posted May 3 Put flat washers under the heads of the screws. Share this post Link to post Share on other sites
kpinnc 12,192 #6 Posted May 4 5 hours ago, rmaynard said: Put flat washers under the heads of the screws. Flat side out! Share this post Link to post Share on other sites
