Ed Kennell
Nuther Whatizit ?
Ed Kennell
8 hours ago, Pullstart said:
Does it attach to a set of lug studs?
Yep, now what's it's purpose?
Pullstart
Holds ‘em down of course!
some type of indicator?  Like a plumb Bob but not?
  • Sad 1
Pullstart
If it’s not a balancer, not an indicator, but goes on lug studs, it’s gotta be an un-balancer!
Ed Kennell
You and Cas should get it.     Keep thinking.     Not gravity.
Pullstart
Caster camber measuring gauge?
  • Sad 1
Pullstart
But automotive?
Ed Kennell
2 minutes ago, Pullstart said:
un-balancer!
It does do that.   What happens when a wheel is un-balanced?
Ed Kennell
But automotive?
Yes, bolts to a DRIVE wheel.
953 nut
It vibrates,   :confusion-shrug:    is this some sort of vibration dampener?
  • Sad 1
Ed Kennell
Visual search query image                                  Clue 1
  • Confused 2
953 nut
What was the clue?          :angry-tappingfoot:
JoeM
your thought I was joking about the backup alarm, just figured it might be a part of one of these.
Ed Kennell
Posted (edited)
No, I've seen those Joe.   This thing is just a weight that creates a centrifical force for a specific purpose.
Edited by Ed Kennell
Ed Kennell
2 hours ago, Pullstart said:
But automotive?
Might work on Collene ?
  • Haha 1
lynnmor
46 minutes ago, Ed Kennell said:
No, I've teen those Joe.   This thing is just a weight that creates a centrifical force for a specific purpose.
The faster you spin, the more the tires dig on a slippery surface.  What did I win?
WHX??
13 hours ago, Ed Kennell said:
He has a barn full of WHATIZITS.
No he has a barn full of cool stuff overlooing the green & yello....:lol:
  • Haha 1
87 416-8 horse
Posted (edited)
Some sort of external counter weight?:confusion-confused:
Edit: sorry, didn’t see page two. Whoops!
Edited by 87 416-8 horse
8ntruck
It is a first generation spinner hubcap.
  • Haha 6
Ed Kennell
Close enough.   The theory is the spinnlng  weight creates a centrifical force that rocks the wheel of the stuck car back and forth when the weight is in the front and rear positions.
When in the down position, yes, it increases the down force and traction.    It was made in York, Pa.
Did it work,  I doubt it ?      As far as I know, the patent is still pending.
  • Like 4
  • Thanks 2
JoeM
i knew that......just didn't want it show off! lol
  • Haha 3
Mickwhitt
I don't understand how it's supposed to do that, surely if the weight is free to pivot on the central bolt it will just hang down no matter what the wheel does?
Am I missing something?
Mickwhitt
Having looked at it again, do you fit it to the wheel with the bolt loose, so you can access all three lug nuts, then lock it with the central bolt to make the wheel out of balance?
If that's right I guess it mimics the action of bouncing up and down on the drive wheels that we try when unbogging a vehicle.
The handles on the back of a Land Rover were fitted to allow helpers to bounce the rear end if it got stuck in mud.
  • Haha 1
953 nut
I think it was designed to put money in the pocket of the manufacturer who would convince unsuspecting gellable people that it would actually work as well as they were telling you it would.          :twocents-02cents:
  • Haha 2
Ed Kennell
Am I missing something?    Probably that the pivot point is not centered in the wheel.
The weight is free to pivot and due to the pivot point not being centered, the spinning wheel may create enough centrifugal force to overcome the graviitational force on the weight.
I have not tested this device and as stated above, I doubt that it did anything to free a stuck vehicle.
Many inventions do not work, but thankfully Orville and Wilber never gave up trying.
SylvanLakeWH
Let's do a Redsquare test!!! Send it to @Pullstart. He can mount it on Colleen the Stuck Bus, call 911 in advance to order medical assistance, set up his ipad, click record, and let the fun begin!!!
:handgestures-thumbupright:
  • Haha 5
