Jakob with a RJ58 garden 0 #1 Posted April 27 I she a RJ 58 garden and I blew the trans on it if there is any one who knows where I can get a rebuild kit for it it will be helpful. Thank you Share this post Link to post Share on other sites
Achto 27,577 #2 Posted April 27 Here is a source for a rebuild kit. He has new 3'rd gears but any other gears you may need will have to be sourced else where. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/ If you need other parts you can post your needs here. https://www.wheelhorseforum.com/classifieds/wanted/ 1 Share this post Link to post Share on other sites
Pullstart 62,884 #3 Posted April 27 there are plenty of video tutorials on rebuilding these from our very own @stevasaurus. He explains everything in great detail! Not too many hoobie doobies inside one of those cases.. https://www.wheelhorseforum.com/forum/144-transmissions/ 2 Share this post Link to post Share on other sites
wallfish 17,000 #4 Posted April 27 Probably better to explain with as much detail as possible on "blew the trans". What actually happened? Could it be stuck in 2 gears at once? Could a shaft key be sheared at the pulley or hub? Shifter broke? There are many things which could happen that don't mean the trans blew. 1 1 Share this post Link to post Share on other sites
stevasaurus 22,740 #6 Posted April 27 Your RJ 58 should have a 3 piece #5003 transmission. Use this video to see what is in it and how it works. 1 1 Share this post Link to post Share on other sites
Ed Kennell 38,178 #7 Posted April 27 to the @Jakob with a RJ58 garden Share this post Link to post Share on other sites
