Wishin4a416 2,191 #1 Posted April 25 What low pressure electric pump are you fellows using on your kohlers? 1 Share this post Link to post Share on other sites
squonk 41,118 #2 Posted April 25 57 minutes ago, Wishin4a416 said: What low pressure electric pump are you fellows using on your kohlers? Facet Posi Flo. The Napa # is 610-1051. but you can probably find one cheaper on line some where. 2 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,299 #3 Posted April 25 I use the same Facet pump. 2 Share this post Link to post Share on other sites
ebinmaine 67,507 #4 Posted April 25 Facet 60245 Or Carter P4070 1 Share this post Link to post Share on other sites
peter lena 8,629 #5 Posted April 25 @Wishin4a416 like the CAR BOL LOW PRESSURE electric pump , on line , have 2 in use , no issues , same style / type as the , facet , pete 1 Share this post Link to post Share on other sites
Achto 27,577 #6 Posted April 26 I am running this pump on a couple of my tractors. No complaints so far. https://www.amazon.com/Electric-Replacement-Motorcycle-Carburetor-Gasoline/dp/B0C4X68SQM?pd_rd_w=tDCl1&content-id=amzn1.sym.b46c8fe2-d558-44b6-a291-82096c829da9&pf_rd_p=b46c8fe2-d558-44b6-a291-82096c829da9&pf_rd_r=MT38T80721ZE8K9KF1FJ&pd_rd_wg=1wbIp&pd_rd_r=65a4cdac-5252-4d17-bc35-d836c473e99b&pd_rd_i=B0C4X68SQM&psc=1&ref_=pd_bap_d_grid_rp_0_1_i 1 Share this post Link to post Share on other sites
Daddy Don 905 #7 Posted April 26 1 hour ago, Achto said: I am running this pump on a couple of my tractors. No complaints so far. https://www.amazon.com/Electric-Replacement-Motorcycle-Carburetor-Gasoline/dp/B0C4X68SQM?pd_rd_w=tDCl1&content-id=amzn1.sym.b46c8fe2-d558-44b6-a291-82096c829da9&pf_rd_p=b46c8fe2-d558-44b6-a291-82096c829da9&pf_rd_r=MT38T80721ZE8K9KF1FJ&pd_rd_wg=1wbIp&pd_rd_r=65a4cdac-5252-4d17-bc35-d836c473e99b&pd_rd_i=B0C4X68SQM&psc=1&ref_=pd_bap_d_grid_rp_0_1_i 1 Share this post Link to post Share on other sites
Daddy Don 905 #8 Posted April 26 Just now, Daddy Don said: I use this same pump no problems 1 2 Share this post Link to post Share on other sites
Racinbob 11,081 #9 Posted April 26 Mr. Gasket #42S. 2-3.5 psi 3 Share this post Link to post Share on other sites
Wishin4a416 2,191 #10 Posted April 26 Thanks everyone!! 1 Share this post Link to post Share on other sites
WHX?? 48,815 #11 Posted April 26 Your I used the same jungle el cheapo Dan posted on customer's z turns. Was worried about how cheap they are but no complaints so far. 2 1 Share this post Link to post Share on other sites
Racinbob 11,081 #12 Posted April 26 2 hours ago, WHX?? said: Your I used the same jungle el cheapo Dan posted on customer's z turns. Was worried about how cheap they are but no complaints so far. I was running one of those on my 854 and it did great. After converting to a K-161 it doesn't need it but I wouldn't hesitate to put it back on at the first hint of an issue. 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #13 Posted April 26 Thanks again fellows!! I was talking to a friend today and He has a Mechanical one he is giving me. If it doesnt work out I will go electric. Jack 2 Share this post Link to post Share on other sites
