Southern_Secret
IT'S a D-180 & IT'S all MINE!!
pfrederi
The motion control linkages on a D Series would make Rube Goldberg envious.  They work OK but it is easy for something to slip out of adjustment and cause problems. Also the linage and parking brake linkage changed once.  Download this manula it has a good section on linkage...
Southern_Secret
Question? What would be a good suggestion for getting the tank unstuck from the seat pan?? :ranting::angry-banghead:
RED-Z06
On 4/26/2024 at 10:08 AM, ebinmaine said:
That looks like the newer style twin. Command?
Try 2575702S
I failed to put the S on the first time
Looks like K532S kohler or thereabouts
Southern_Secret
As of my knowledge it is the original motor.
pfrederi
Parts manual shows two different carb kits.  What is eh spec number for your engine and the serial #
Southern_Secret
Just A little work done yesterday, got the weight and wheels off & up on stands :handgestures-thumbupright:
  • Heart 1
Southern_Secret
@pfrederi the numbers on the engine are gone so im not 100% sure
pfrederi
Based on the spec number that WH used the most 53105 The carb is variation 14.  However there is split between serial #s   older use 25757 01  later used 257502.  Will look at the serial # on my D200 later may give a clue...
  • Heart 1
Southern_Secret
The I.D. plate off the tractor
  • Confused 1
pfrederi
Posted (edited)
That model number is for a  1975  D180 so you have the K 482 probably spec #35222 and is still carb variation 14.
The break point for 6373508  seems to be in mid 1974.  Hazard a guess you are after that so use the 2575702 kit
Edited by pfrederi
Southern_Secret
Posted (edited)
The Seat pan & Tank decided to go there separate ways thank goodness :handgestures-thumbupright:
Edited by Southern_Secret
Southern_Secret
Any suggestions on getting the hubs off?? :ranting:
ebinmaine
That's a special science in itself.
A#1. Do NOT use a standard 3 jaw puller.
Any pics of where you're at?
RED-Z06
And dont hit the back of the hubs...
pfrederi
Posted (edited)
One of the more difficult tasks in WH land.  The body of the hub is much longer than other horses so there is more surface for rust to build a bond between the hub and the axle.  The flange is only slightly thicker than normal.  If you try to pull on the flanges you will mostly likely break it if the hub is stuck on .  You need to pull from the back of the hub.  This is how I did mine a few years ago...never hope to have to do that again.  You will note the square tubing has a bend to it.  It was straight when I started...
Edited by pfrederi
Southern_Secret
Been away a few day cause of a death in the family, but I will get some pics posted soon I hope.
peter lena
@Southern_Secret  good luck with that , to me its a perfect time to save the period patina , with a penetrating oil soak down , think about , once its wet with oil , and the days and weeks or more go by , with more important areas . the existing paint has been drinking in that patina saving lube , ready for a oiled cloth rub down ,  another thing is to look at cracking stress areas , on you to do list , pete
  • Similar Content
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Nathan W
      By Nathan W
      Does this look factory for 1976
