John c 77 #1 Posted April 23 I went sunday and picked up the 314H I'd found. It's in good original condition besides the tires, and a few seat cover cracks, looks like it'd been kept out of the weather til I brought it home in the rain, cranks and runs like new. 48" deck is solid top and bottom, the spindles are not corroded and spin freely. I'll go over it service the fluids, filters etc, clean the deck, inspect the bearings, belts etc. I'd been wanting a hydro drive WH for some time, I'm glad to have found it. 4 9 Share this post Link to post Share on other sites
OutdoorEnvy 1,510 #3 Posted April 23 That looks nice! Great find for sure 1 Share this post Link to post Share on other sites
OoPEZoO 500 #4 Posted April 23 Well done….I’ve always thought the 314-H was the perfect mix of simple yet very capable. That one looks like it will be an easy clean up and should be an excellent tractor. How many hours on it? 3 Share this post Link to post Share on other sites
peter lena 8,460 #5 Posted April 23 @JOHN C. agree with others on a great catch , personally , a great time to get some penetrating oil on / in that paint finish , for a base line recovery . like an initial spray / wipe down with a clean cloth , let it sit for days . to soak in the lube , forget about it . while you are doing other things . also inside / heat , enhances the lubricant soak . do that a couple of times , then a 6" electric palm buffer with cleaner wax , nothing rough , just see how it breaks thru the grunge . have had very good results , on recovery paint . that dull , flat looking paint needs a feeding . relatively easy too, done this on my 3 horses , just an idea , pete 1 Share this post Link to post Share on other sites
Moparfanforever 824 #6 Posted April 23 Good find!! It will last you a long time. 1 Share this post Link to post Share on other sites
rjg854 11,241 #7 Posted April 23 Nice it even has hub caps and even they look to be in nice shape. 1 Share this post Link to post Share on other sites
kpinnc 11,498 #8 Posted April 23 @OoPEZoO That's a very nice find @John c. Agree a 314H is a great machine. Magnum reliability, Eaton 1100 transmissions are the best. You got high end power without all the electrical issues of a 500 series. That tractor should handle everything you throw at it. Very nice save! 2 Share this post Link to post Share on other sites
Brockport Bill 1,556 #9 Posted April 23 suggest when you are servicing it you look underneath and check the tranny frame plate that has 4 bolts attaching main frame to transmission -- be sure it doesn't have a stress crack fracture? 1 1 Share this post Link to post Share on other sites
PWL216 868 #10 Posted April 23 3 hours ago, OoPEZoO said: Well done….I’ve always thought the 314-H was the perfect mix of simple yet very capable. That one looks like it will be an easy clean up and should be an excellent tractor. How many hours on it? Agreed. I have a 314-H and a 314-8. Both are very capable machines. 1 Share this post Link to post Share on other sites
peter lena 8,460 #11 Posted April 23 @Brockport Bill excellent reference point , there are so many things to look at on a recent pick up , always add something that was not even a thought , suggest a maintenance look over , think I would , do some cross bracing ,and weld over that crack . thats frame twist , generated , pete Share this post Link to post Share on other sites
John c 77 #12 Posted April 23 I took the back fender/seat off and cleaned off the drive unit this morning, Before...... Share this post Link to post Share on other sites
John c 77 #13 Posted April 23 (edited) it says I've maxed out the MBs, can't show the after pictures Edited April 23 by John c Share this post Link to post Share on other sites
ebinmaine 66,573 #14 Posted April 23 Just now, John c said: it says I've maxed out the gigs If you become a site supporter there's no limit and your name will look good in red! Share this post Link to post Share on other sites
John c 77 #15 Posted April 23 f you become a site supporter there's no limit and your name will look good in red!............Well that's easy enough to fix I guess So here it is after I washed it. 2 2 Share this post Link to post Share on other sites
John c 77 #16 Posted April 23 Can somebody tell me the year of mfg, Share this post Link to post Share on other sites
Brockport Bill 1,556 #17 Posted April 23 5 minutes ago, John c said: Can somebody tell me the year of mfg, per partstree.com its 1994 Share this post Link to post Share on other sites
Bill D 1,833 #18 Posted April 23 1 hour ago, John c said: f you become a site supporter there's no limit and your name will look good in red!............Well that's easy enough to fix I guess So here it is after I washed it. Take off the cross bar that holds the front tabs on the gas tank and check for cracks where it mounts to the hood stand. Add thick fender washers when reassembling. 2 Share this post Link to post Share on other sites
Fordiesel69 258 #19 Posted April 23 So that is the tractor you were referring to in you transmission post? I am sooo jealous. It is getting hard and harder to find nice ones like that. And with a 48" deck and those hubcaps you really got a nice package. Most of these had a 42" on them. 1 Share this post Link to post Share on other sites
lynnmor 7,245 #20 Posted April 23 Be sure to oil every pivot point in there while it is apart, I use motorcycle chain oil so it has some staying power. Do not oil the friction washers on the speed cam plate. 1 Share this post Link to post Share on other sites
Handy Don 11,886 #21 Posted April 23 5 hours ago, John c said: it says I've maxed out the MBs, can't show the after pictures It’s a worthwhile skill to learn how to downsample photos and/or change formats. Lots of good YouTubes for iPhone, Macs, Windows, and Android. Saves room in emails and on servers like Red Square! Share this post Link to post Share on other sites
Moparfanforever 824 #22 Posted April 23 Looks very sharp!! A person gets alot of satisfaction from a good power washing. 1 Share this post Link to post Share on other sites
ebinmaine 66,573 #23 Posted April 23 2 minutes ago, Moparfanforever said: A person gets alot of satisfaction from a good power washing. Of the person or .....? Share this post Link to post Share on other sites
John c 77 #25 Posted April 24 fordiesel69, yes this is the tractor I was looking at when I was asking about different hydro brands, was also looking at a C160, but this one won out. This make 2 WH for me now, my other is a 314-8. I'm stoked to have it, Share this post Link to post Share on other sites
