John c
314-H
ebinmaine
Good catch!
OutdoorEnvy
That looks nice!  Great find for sure
OoPEZoO
Well done….I’ve always thought the 314-H was the perfect mix of simple yet very capable. That one looks like it will be an easy clean up and should be an excellent tractor. How many hours on it?
peter lena
@JOHN C.  agree with others on a great catch ,  personally , a great time to get some  penetrating oil on  / in that paint finish , for a base line recovery . like an initial spray / wipe down with a clean cloth , let it sit for days . to soak in the lube ,  forget about it . while you are  doing other things . also inside / heat , enhances the lubricant soak . do that a couple of times , then a 6" electric palm buffer with cleaner wax , nothing rough , just see how it breaks thru the grunge . have had very good results , on recovery paint .  that dull , flat looking paint needs a feeding . relatively easy too,  done this on my 3 horses , just an idea , pete
Moparfanforever
Good find!! It will last you a long time.
:thumbs:
rjg854
Nice it even has hub caps and even they look to be in nice shape.  :handgestures-thumbupright:
kpinnc
@OoPEZoO
That's a very nice find @John c. Agree a 314H is a great machine. Magnum reliability, Eaton 1100 transmissions are the best. You got high end power without all the electrical issues of a 500 series. That tractor should handle everything you throw at it. Very nice save! :thumbs:
Brockport Bill
suggest when you are servicing it you look underneath and check the tranny frame plate that has 4 bolts attaching main frame to transmission -- be sure it doesn't have a stress crack fracture?
PWL216
Agreed. I have a 314-H and a 314-8. Both are very capable machines.
peter lena
@Brockport Bill  excellent reference point , there are so many things to look at on a recent pick up , always add something that  was not even a thought , suggest a maintenance look over , think I would , do some cross bracing ,and weld over that crack . thats frame twist , generated , pete
John c
I took the back fender/seat off and cleaned off the drive unit this morning,
Before......
John c
it says I've maxed out the MBs, can't show the after pictures
Edited by John c
ebinmaine
Just now, John c said:
it says I've maxed out the gigs
If you become a site supporter there's no limit and your name will look good in red!
John c
f you become a site supporter there's no limit and your name will look good in red!............Well that's easy enough to fix I guess
So here it is after I washed it.
  • Excellent 2
John c
Can somebody tell me the year of mfg,
Brockport Bill
per partstree.com its 1994
Bill D
Take off the cross bar that holds the front tabs on the gas tank and check for cracks where it mounts to the hood stand.  Add thick fender washers when reassembling.
Fordiesel69
So that is the tractor you were referring to in you transmission post?
I am sooo jealous.  It is getting hard and harder to find nice ones like that.  And with a 48" deck and those hubcaps you really got a nice package.  Most of these had a 42" on them.
lynnmor
Be sure to oil every pivot point in there while it is apart, I use motorcycle chain oil so it has some staying power.  Do not oil the friction washers on the speed cam plate.
Handy Don
It’s a worthwhile skill to learn how to downsample photos and/or change formats. Lots of good YouTubes for iPhone, Macs, Windows, and Android.
Saves room in emails and on servers like Red Square!
Moparfanforever
Looks very sharp!!
A person gets alot of satisfaction from a good power washing.
:thumbs:
ebinmaine
Of the person or .....?
:hide:
Moparfanforever
Both
:thumbs:
  • Haha 1
John c
fordiesel69, yes this is the tractor I was looking at when I was asking about different hydro brands, was also looking at a C160, but this one won out. This make 2 WH for me now, my other is a 314-8. I'm stoked to have it,
