Hank M 0 #1 Posted April 18, 2024 I have a 1991 Toro 244H lawn tractor with the hydrostatic transmission.. For the last few years it would slow down up hills and speed up going down. Recently it is very jerky and won't even climb a steep hill. Any help on diagnosing and repairing this?. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #2 Posted April 18, 2024 Here is what we have on the model in random order. There is a SM (service manual) in the list. https://www.wheelhorseforum.com/search/?q=22-14OE01&quick=1&type=downloads_file 1 Share this post Link to post Share on other sites
WHX?? 57,878 #3 Posted April 18, 2024 Is the fluid level correct or does it leak fluid? If it is about the only thing one can do externally is check the linkage. Peerless if I remember right and probably not worth taking apart & repairing. . Should be a few donor transaxles out ther I know I have a couple. For those not aware this tractor is a vert. and the tranny is a top loader or top drive. 1 Share this post Link to post Share on other sites
953 nut 68,739 #4 Posted April 19, 2024 (edited) If you haven't already done so I would suggest draining the oil from the transmission and replacing it with some fresh 30-W motor oil and use a new filter, NAPA 1410 or Wix 51410. Edited April 19, 2024 by 953 nut Share this post Link to post Share on other sites
WHX?? 57,878 #5 Posted April 19, 2024 No can do Richard. If memory serves ther is no decent way to drain and they don't have a filter just an internal screen. If an Eaton you can rebuild them but often not worth it. Totally different than a 1100 fer sure. Share this post Link to post Share on other sites
953 nut 68,739 #6 Posted April 19, 2024 17 hours ago, gwest_ca said: https://www.wheelhorseforum.com/search/?q=22-14OE01&quick=1&type=downloads_file 23 minutes ago, WHX?? said: they don't have a filter The list of info Garry sent along has a service bulletin using 30-W oil and another post about the oil filter. Must admit I have never had a vertical shaft hydro, just going by what was in the files section. Share this post Link to post Share on other sites
Hank M 0 #7 Posted May 3, 2024 I'm the OP of this thread. First, i would like to thank everyone who has taken the time to respond. Further troubleshooting revealed that the drive belt was in poor condition. I remove and replaced it with a new one. It's running much better, I believe this mower has a few more years of service in it now. Share this post Link to post Share on other sites
