Kimhoff
212-6 Transmision
Kimhoff
All,
New here.  I have a 212-6 Wheel Horse and having shift problems.  It has a 920-010 Peerless.  Can this transmission be shifted on the go or is the clutch needed to shift this?
Thanks
gwest_ca
Welcome to Red Square.
Sounds like you could use an operator manual. If it has a clutch it's use is required to change gears. Most models also require the tractor wheels must be stopped before selecting a different gear.
Handy Don
Posted (edited)
@Kimhoff, Trying to shift on the go, even with clutching, is a very easy way to wreck the transmission.
Edited by Handy Don
