ebinmaine 69,996 #1 Posted April 11, 2024 Can somebody tell me what the lift link chain specs are? We have a couple different ones here that vary a little bit. Also, is there a simple procedure for adjusting the length of the trunnion and screw when setting up a deck? Share this post Link to post Share on other sites
squonk 42,056 #2 Posted April 11, 2024 I don't think the size matters. I've had several different sizes on tractors.As far as adjustments, raise the lift and tighten the nut so the rubber bumpers on the deck are against the footboards. 4 1 Share this post Link to post Share on other sites
ri702bill 8,821 #3 Posted April 11, 2024 I don't think the size matters... Not to often that this is the case, but it is. Adjusting the trunnion, regardless of the chain style, sets the height. On the C81, I find it easier to remove the lower dash panel to get better access..... I remove the chain and trunnion for plowing - I use a solid link to give down pressure. The chain setup goes back on - untouched - when the deck goes back on... 1 1 Share this post Link to post Share on other sites
peter lena 9,023 #4 Posted April 11, 2024 @ri702bill agree on the dash panel , also gives you an opportunity to washer up that sloppy trunnion hook up , note side play , wearing out the slide in clip ? firm that up / grease it , makes it solid smooth , also a spot to try a HEIM JOINT , just sayin , pete 1 Share this post Link to post Share on other sites
ebinmaine 69,996 #5 Posted April 11, 2024 9 minutes ago, peter lena said: also gives you an opportunity to washer up that sloppy trunnion hook up , note side play , wearing out the slide in clip Pete, you'd be happy with Trina because the first thing she did on reassembly was go hunting around for the right thickness washer and put a new clip in there... 1 1 Share this post Link to post Share on other sites
peter lena 9,023 #6 Posted April 11, 2024 @ebinmaine yup , regularly , looking right at you ! more often than not , firming up linkage / lever ends , lube , make s it all good . after detailing a chronic lever , like PTO AREA , it works so easily / smoothly , hard to believe its the same hook up , pete Share this post Link to post Share on other sites
Handy Don 13,142 #7 Posted April 12, 2024 On 4/11/2024 at 6:21 AM, squonk said: As far as adjustments, raise the lift and tighten the nut so the rubber bumpers on the deck are against the footboards. This is my system, as well. When setting up new chain or deck, it’s Important to start by loosening the eyebolt through the trunnion first, especially if you have a hydro lift, lest it crunch the deck frame against the tractor frame. 😬 Share this post Link to post Share on other sites
squonk 42,056 #8 Posted April 12, 2024 18 minutes ago, Handy Don said: This is my system, as well. When setting up new chain or deck, it’s Important to start by loosening the eyebolt through the trunnion first, especially if you have a hydro lift, lest it crunch the deck frame against the tractor frame. 😬 I've seen that hydro lift cause the lift arm to smack the steering block on some of them. 1 Share this post Link to post Share on other sites
