Don in Mystic
C-100, Need Starter Brushes
Don in Mystic
I have a 1974 C-100 . The Starter is an "American Bosch" model SMA 12A11 which needs a set (2) of new brushes. Ive searched Amazon, Ebay and the web without success. Hoping someone can suggest a source. Many ThanksDSCF3233.JPG.c395b65608c6d99393ea43ff9cc24b64.JPG
Don in Mystic
Thanks but the kit pictured in the link isn't the correct one (ask me how I know).  I have a two brush starter and the braided wire attached at the end, not side of the brush
953 nut
I don't know what starter you have, just used that listing as a reference. Give them a call, they probably have what you need.
ri702bill
Don - do you have a Starter / Generator / Alternator Rebuilding facility near you?? They may have exactly what you need....
Don in Mystic
Unfortunately, no longer but I am going to expand my search area and hopefully find one.....
oliver2-44
You could also try DB Electric. I have bought brush, bushing kits from them.  If your starter has enough use that the brushes are worn out, I would suggest you check the front bushing for wear. They are prone to wear as they take all the side loading
Edited by oliver2-44
ebinmaine
3 hours ago, oliver2-44 said:
DB Electric
That was one thought I had.
Also maybe isavetractors...?
ebinmaine
@WHX?? or @Achto
You guys got any vendors up by you?
Achto
My "Go To" guy left the area.:(
  • Sad 2
WHX??
Not anymore ... our guy moved to Timbukto..Sounds like he already covered our usual haunts. Maybe Pat's small engine plus? Lately he's been boning me too tho.
I would think they should be easy to find.
Try Googling Bosch brushes sma 12a11 being keywords.
Don in Mystic
I got Lucky
I saw a set on ebay that looked like them and turns out I was right. FYI part #s for reference are
Brush Kit:
Kohler 236576
Bosch 551005
Thanks to those who replied
ebinmaine
32 minutes ago, Don in Mystic said:
I got Lucky
Brush Kit:
Kohler 236576
Bosch 551005
@gwest_ca
Is there a section or page where the above information could or should be added?
