ebinmaine 67,502 #1 Posted April 9 This question is primarily about a late seventies c121 Hydro 36-in RD deck Drive belt. Looks to me like it's supposed to be a standard rubber type 1/2 in wide 96.5 or 96.7 inches in length. Is there an aftermarket belt other than the Gates Blade Runner that I can use? Will a normal average everyday ½ by 97 drive this okay? Are these the same belts used on Long frame tractors for other sizes of mower decks as well? 2 Share this post Link to post Share on other sites
squonk 41,118 #2 Posted April 9 If your deck has the std sliding idler deck pulley like a 42" RD deck has I don't see why you can't run a Tractor Supply 1/2 X 97 belt on it. I run a TSC on mine and I believe it's 97" 2 1 Share this post Link to post Share on other sites
ebinmaine 67,502 #3 Posted April 9 30 minutes ago, squonk said: If your deck has the std sliding idler deck pulley like a 42" RD deck has I don't see why you can't run a Tractor Supply 1/2 X 97 belt on it. I run a TSC on mine and I believe it's 97" Model number decal is wiped clean unfortunately. 2 Share this post Link to post Share on other sites
Ed Kennell 38,178 #4 Posted April 9 Some of those tension bars have two different holes for the idler pulley. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,299 #5 Posted April 9 I'll have a part number for you in a couple of minutes I get my belts from Advance auto. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,299 #6 Posted April 9 I use a Dayco L497 for 36 or 42 inch rd decks. 3 1 Share this post Link to post Share on other sites
squonk 41,118 #7 Posted April 9 L497 crosses to Napa/Gates 4L970W Tractor Supply 4L970K 3 2 Share this post Link to post Share on other sites
ebinmaine 67,502 #8 Posted April 9 You guys are awesome! 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,299 #9 Posted April 9 Now you made Sir Skunky's head bigger ! 3 Share this post Link to post Share on other sites
squonk 41,118 #10 Posted April 9 1 hour ago, elcamino/wheelhorse said: Now you made Sir Skunky's head bigger ! And it's full of info! 2 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,299 #11 Posted April 9 Okay Dr. Info , what kind of fuel filter do you have on the 953 ? The picture looked like a clear (glass/plastic ) thingy with brass fittings ? Share this post Link to post Share on other sites
squonk 41,118 #12 Posted April 9 27 minutes ago, elcamino/wheelhorse said: Okay Dr. Info , what kind of fuel filter do you have on the 953 ? The picture looked like a clear (glass/plastic ) thingy with brass fittings ? Brass 1/8" thread 45deg street elbow. Metal fuel filter that came with the pump. 1/8 thread x 5/16 hose equivalent to a Napa 3046 2 1 Share this post Link to post Share on other sites
ebinmaine 67,502 #13 Posted April 10 37 minutes ago, elcamino/wheelhorse said: Dr. Info @squonk. Ya should take that as a right solid compliment. I've been called waaaaaaay worse. 2 Share this post Link to post Share on other sites
ebinmaine 67,502 #14 Posted April 10 2 hours ago, elcamino/wheelhorse said: I use a Dayco L497 for 36 or 42 inch rd decks. How bolt SD decks? 42" and 48" on a C series Share this post Link to post Share on other sites
elcamino/wheelhorse 9,299 #15 Posted April 10 I think they use the same belt. Only have one SD and it is set up for leaves. 1 Share this post Link to post Share on other sites
peter lena 8,628 #16 Posted April 10 @ebinmaine as you are aware , the belt deck " bounce " is a result of incremental , bearing hang up , the more it bounces , the more rotational / bearing issues are evident . have detailed my flat idler pulley , like a larger bearing , bush the inner to 3/8 same bolt fit . also have added a flat idler ,on the back unsupported area , about middle of long run , drill a hole , 3/8 bolt , elastic lock nut. have that on 3 decks . no belt buzzes, Pete 1 Share this post Link to post Share on other sites
aemsee 93 #17 Posted April 14 (edited) I measured the external length of the deck belt for my 36" RD mower. It is 77". ?? 97" just seemed incredibly long for my deck. Edited April 14 by aemsee 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,045 #18 Posted April 15 4 hours ago, aemsee said: I measured the external length of the deck belt for my 36" RD mower. It is 77". ?? 97" just seemed incredibly long for my deck. Drive belt 102741 (1/2" x 96.6") for B-Series & C-Series tractors with 45-1/2" wheelbase (Gates replacement BladeRunner 6638BR 17/32" x 96.75") Spindle belt 8411 (1/2" x 76.94") 1 Share this post Link to post Share on other sites
aemsee 93 #19 Posted April 15 2 hours ago, gwest_ca said: Drive belt 102741 (1/2" x 96.6") for B-Series & C-Series tractors with 45-1/2" wheelbase (Gates replacement BladeRunner 6638BR 17/32" x 96.75") Spindle belt 8411 (1/2" x 76.94") my bad. Thought he was looking for the deck belt. thanks 1 Share this post Link to post Share on other sites
ebinmaine 67,502 #20 Posted August 8 On 4/14/2024 at 10:48 PM, aemsee said: my bad. Thought he was looking for the deck belt. thanks Might be four months late but I AM now looking for a deck belt. So your post was excellent and valid! Share this post Link to post Share on other sites
ebinmaine 67,502 #21 Posted August 8 On 4/14/2024 at 8:00 PM, gwest_ca said: Drive belt 102741 (1/2" x 96.6") for B-Series & C-Series tractors with 45-1/2" wheelbase (Gates replacement BladeRunner 6638BR 17/32" x 96.75") Spindle belt 8411 (1/2" x 76.94") Any of you folks know if I can use a box store 1/2" x 77" belt for the deck pulleys? Share this post Link to post Share on other sites
ebinmaine 67,502 #22 Posted August 17 On 4/10/2024 at 11:24 AM, peter lena said: @ebinmaine as you are aware , the belt deck " bounce " is a result of incremental , bearing hang up , the more it bounces , the more rotational / bearing issues are evident . have detailed my flat idler pulley , like a larger bearing , bush the inner to 3/8 same bolt fit . also have added a flat idler ,on the back unsupported area , about middle of long run , drill a hole , 3/8 bolt , elastic lock nut. have that on 3 decks . no belt buzzes, Pete Pete do you have any pics of where you've added idlers? On 4/14/2024 at 3:02 PM, aemsee said: I measured the external length of the deck belt for my 36" RD mower. It is 77". ?? 97" just seemed incredibly long for my deck. What brand deck belt are you using? Share this post Link to post Share on other sites
peter lena 8,628 #23 Posted August 17 @ebinmaine second and fifth picture down , you are looking left to inside of mower deck , placed idler about in the middle of unsupported area , drilled a 3/8 hole in deck , longer thread free pulley mount , washers on each end and elastic lock nut , worked so well , have it on all my decks . like most of my mods , its on the detail of function , retaining original , intent , enhancing ease of function . none of my belt drives , have the wide , unsupported idler slide arm buzz , also re greased idler bearing , pete 1 Share this post Link to post Share on other sites
