Richard Wahlstrand 81 #1 Posted April 9 (edited) Fellow enthusiasts, I acquired my 416-8 with under 1000-hours about three years ago. I have three low-hour 300-series machines and wanted one with an Onan twin engine. The 300's are in storage and will probably become inventory in the estate sale. The 416's hours did not concern me because the seller was the original 30-year owner. He said that he changed oil and filter three times per season which calculated to about every 10-hours. I wanted the machine as a tow tractor and a toy. After reading member's improvements, I decided to post mine. They may be of value or amusement. - Cut a piece of 1x wood to fit under the battery to reinforce the tray; - Replaced the factory tail light bulbs with LED strobes/flashers that are plug and play; The bulbs will either flash continuously or be in the normal "On" mode. - Strapped a small LED strobing flash light to the top of the hood; I want the strobe on when I am on the street. - Installed an Oregon in-line fuel shut-off in the line above the clutch The oil drain piping started leaking. It required loosening the engine mounting bolts to lift the engine less than an inch so that the elbow would clear for removal. I bought new 3/8-inch npt pipe nipples and elbow at a local home improvement store for under $10. I applied paste-type thread sealer and screwed the new nipple into the engine base and then the elbow and second nipple to complete the new drain pipe assembly. Months later and no leaks Next on my list: - Convert rear wheel to studs (Thanks to the many comments from other Forum members) - Install Kevlar drive belt Thanks to others for sharing their successes and lessons learned Richard, a retiree from the big green tractor company Edited April 9 by Richard Wahlstrand i added about the oil drain piping. 8 5 Share this post Link to post Share on other sites
ebinmaine 67,422 #2 Posted April 9 2 hours ago, Richard Wahlstrand said: Convert rear wheel to studs I keep a list of needed parts. Lemma know if I can help. Great to see the old Horse getting some use and maintenance! 2 Share this post Link to post Share on other sites
Horse Newbie 7,069 #3 Posted April 9 3 hours ago, Richard Wahlstrand said: a retiree from the big green tractor company We won’t hold that against you… 3 Share this post Link to post Share on other sites
Handy Don 12,212 #4 Posted April 9 3 hours ago, Richard Wahlstrand said: retiree from the big green tractor company Lots of members here have plenty of respect for (and own) other makes--variety can be the spice of life, right? You may see an occasional question aimed at you posted in the Other Brands area! 1 Share this post Link to post Share on other sites
Blasterdad 2,692 #5 Posted April 9 4 hours ago, Richard Wahlstrand said: Richard, a retiree from the big green tractor company That says a lot about our beloved 's. When is the estate sale? 1 3 Share this post Link to post Share on other sites
Richard Wahlstrand 81 #6 Posted April 9 After I assume room temperature... hopefully in a few years. 1 8 Share this post Link to post Share on other sites
ebinmaine 67,422 #7 Posted April 10 1 hour ago, Richard Wahlstrand said: After I assume room temperature... 1 Share this post Link to post Share on other sites
Pullstart 62,834 #8 Posted April 10 If I haven’t before, 2 Share this post Link to post Share on other sites
Richard Wahlstrand 81 #12 Posted April 10 10 hours ago, 953 nut said: Thank you, Richard. Richard Wahlstrand U.S. Army, Vietnam Class of '72 1 2 Share this post Link to post Share on other sites
ebinmaine 67,422 #13 Posted April 10 1 hour ago, Richard Wahlstrand said: Thank you, Richard. Richard Wahlstrand U.S. Army, Vietnam Class of '72 Share this post Link to post Share on other sites
Retired Wrencher 5,450 #14 Posted April 11 On 4/9/2024 at 2:03 PM, Richard Wahlstrand said: Fellow enthusiasts, I acquired my 416-8 with under 1000-hours about three years ago. I have three low-hour 300-series machines and wanted one with an Onan twin engine. The 300's are in storage and will probably become inventory in the estate sale. The 416's hours did not concern me because the seller was the original 30-year owner. He said that he changed oil and filter three times per season which calculated to about every 10-hours. I wanted the machine as a tow tractor and a toy. After reading member's improvements, I decided to post mine. They may be of value or amusement. - Cut a piece of 1x wood to fit under the battery to reinforce the tray; - Replaced the factory tail light bulbs with LED strobes/flashers that are plug and play; The bulbs will either flash continuously or be in the normal "On" mode. - Strapped a small LED strobing flash light to the top of the hood; I want the strobe on when I am on the street. - Installed an Oregon in-line fuel shut-off in the line above the clutch The oil drain piping started leaking. It required loosening the engine mounting bolts to lift the engine less than an inch so that the elbow would clear for removal. I bought new 3/8-inch npt pipe nipples and elbow at a local home improvement store for under $10. I applied paste-type thread sealer and screwed the new nipple into the engine base and then the elbow and second nipple to complete the new drain pipe assembly. Months later and no leaks Next on my list: - Convert rear wheel to studs (Thanks to the many comments from other Forum members) - Install Kevlar drive belt Thanks to others for sharing their successes and lessons learned Richard, a retiree from the big green tractor company Richard I am sure you see a lot green there riding around and cutting grass or what ever. I know when I go visit my brother in VT It is that way. Enjoy the ride. Share this post Link to post Share on other sites
